Results 1 to 15 of 16
Thread: can a 4agze run on 195 cc injectors?
    south australia
    Default can a 4agze run on 195 cc injectors?
    i just went to check to see what the injectors were like out of my GZE, i check the part number and according to the denso list, they are only 195cc.
    i remember the engine would run real rich. standard ecu and AFM. has someone swapped the injectors before i had the car?
    the number is 23250-16060.
    Default Re: can a 4agze run on 195 cc injectors?
    You would be leaning out big time at WOT on boost with those injectors. Are you sure there not the 23250-16061- they are the 365cc ones...
    Current Cars:
    Probably the denso list is mis-printed. Can you compare to another set of GZE injectors? Or do they have different part numbers?
    south australia
    well they definetly have 16060 on them. and they have orange tops. it was pouring black smoke out the rear when i had it on the road, indicating to me that is mas rich. (the afm was a bit dicky tho)
    i thought they were 365....until today
    Mass rich wouldnt that equal too much fuel? Therefore larger than standard??
    south australia
    yeah well thats what i thought. but the number says otherwise.....
    i think the AFM was the biggest cause of the problem, but still, it doesnt explain why i have these in my engine
    Im checking out on ze google and from all reports orangey/red nippn denso = gze injectors.
    south australia
    i am about to confirm it on ae86 dc. there is a set for sale that look the same. gettting part number
    thanks for your input!
    to be 100% sure of what you the injectors are, get them cleaned and flowed - you probably should do that if you buy second hand injectors anyway.
    Current Cars:
    S.A
    Slide: Do you have a pic of em ??? I dont know the part no. of a GZE injector but i do know what the 2 types of GZE injectors look like.
    I thought you were running 550cc Anyway ??? --Is this another car ??
    I found this on google?
    Individual part numbers for the injectors are as follows:
    23209-16060 - 01 = Blue
    23209-16060 - 02 = Black
    23209-16060 - 03 = Yellow
    23209-16060 - 04 = White
    195 would be barely enough to feeda 4AGE at full noise.
    they will not support a GZE at full boost/revs for sure.
    Jun 2006
    4 X 195cc injectors at 80% duty cycle with a BSFC of 0.65 (mid range for a forced induction motor) will support about 123kw.
    regards
    jon
    Cleveland QLD
    I have just checked mine and they are 23250-16060 from an early GZE. Same as Slide86.
    Sydney N.S.W
    195cc should support the GZE
    210cc are used for 18rgeu's
    unless the problem lies in the injectors being high imp (60) and low for the (61s)
    These was a set of 365's for sale which were orange/red, multi spray and they were (61's) from memory.
    just throwing it out there.
  1. Aftermarket engine management and injectors
    Last Post: 14-05-2006, 02:05 PM
  2. mechanical specs for 4agze injectors
    Last Post: 04-01-2006, 01:05 AM
