I'd pull every vac hose off the engine and replace it with either new new new rubber vac hose, or the older good stuff toyota use to use. Some where along the line (20v era) toyota must've changed rubber tubing supplier, or the supplier changed the rubber because it all falls apart.
It splits around the edges where it's been pushed over the nipples, it cracks around bends, and it generally just falls to bits.
I've seen a few and it seems to be a common problem, if it's idling crazy, you're definately getting more air.
Dan
