have you touched the AFM though ?
 whats wrong with my 20V?
				I put my 20V under high load and one of my extractor primary pipes cracked, as soon that happened the engine started to behave strangely. It started to idle at 2000 revs and sometimes rapidly fluctuate to 1500 revs and back up again. It has since used a considerable amount of fuel. I fixed the extractors and its still the same. I bridged my ECU and did a diagnosis and it has no fault codes so I am confused as to what is wrong. The only thing I can think of is that my idle control motor has gone haywire or my air flow meter is damaged.
Any ideas guys?
 Re: whats wrong with my 20V?
What is autosalon? Sounds kinda homo.
Slayer Of Toymods Wookie SlayersOriginally Posted by tooch
				didnt go near it, i heard they are sensative things though and I thought a small backfire that I didnt know of hit it, does bouncing off a rev limiter do that?
				first guess is to investigate the idle control motor and AFM first rough idle is normally associated with that... and yea if you're idling high, fuel consumption would definitely go through the roof.. (obviously)
Last edited by Vios-GT_07; 14-09-2006 at 11:40 PM. Reason: just noticed your log.. my idea is wrong
				I'd hazard a guess that the cracked exhaust pipe and the idling high are totally unrelated. A cracked pipe will take a while to start and progress, the idling sounded like it started suddenly. So don't get too caught up in trying to work out what would cause both.
Check the usual things, vacuum leak, idle valve, throttles closing and signalling idle properly etc...
Hen
				run engine and block the intake to the air flow while holding revs abit up
it should stall if it doesnt it might have an air leak
another hting to check is throttle linkages
idle motor will prob not make it idle so hi
so prob u got shit in throttles holding butterflies open or maybe something similar
				It has the wrong number of inlet valves and a crappy combustion chamber.whats wrong with my 20V?
</thread hijack>
				thanks guys, how do I check my airflow meter? or my idle control valve other than what sideshow says.
Bill: hehehe yes I know all about the how the middle intake valve is too shrouded by the outside ones and the lack of a proper squish design in this head, I still dont get why toyota made this engine. I wonder what would of happened if they introduced a 20v style intake, vvt and individual throttles on an updated 16V engine, would be a ripper I think.
				the other thing I forgot to mention is that it "pops" alot as in small backfires. This is on throttle lift off so doesnt that narrow it down to air-flow meter or the TPS?
				if it was runnin ok then all of a sudden fukt up
then it cant be too much wrong
air flow and stuff just dont fuk up easily
did it stuff up on a dyno or did u give it a thrashinbg for more than 5 mins
whats yr fuel pressure like
fule p[umps fuk up mopre often than air flows and things like that
tps will nt go out u8nless something else goes wrong
alot fo the time i fix probs that are not eletrically related
so at the moment try not to blame electrical shit especially when u get no codes from ecu
				If it's popping with throttle backed off i.e. slowing down,driving down a hill.
An exhaust leak can cause this. i.e. your cracked header pipe.
1990 ST185 GT4 3SGTE
1991 ST184 SX 3SGTE
1991 SW20 GT 3SGTE
1998 ST215 GTT 3SGTE
2008 VDJ200 Sahara
				With your other problem i am thinking that maybe your coolant temp sensor reading too cold. i.e. telling your ecu your engine is colder than what it really is. This would affect your idling and your fuel economy.
1991 ST184 SX 3SGTE
1991 SW20 GT 3SGTE
2008 VDJ200 Sahara
				timing and air fuel ratio could cause this... especially when u're still in gear when this happensOriginally Posted by Sam_Q
plus your header cracking... while it's worth it to investigate the pipe construction and all that.. maybe it's also worth a few a little while to look at the engine, maybe it's running too lean causing header to heat up too much? could also explain the popping...?
				sideshow: I was pissed off at someone and I had some bad tyres on so I dumped the clutch and let it bounce off the 7200RPM limiter (no speed sensor hence lower rev limit). I dont know what my fuel pressure is like, any ideas?
cruiser: the pipe is fixed now but it still backfire, I was also thinking that it was the coolent temp sensor, the reason I think its quite possible is because when its cold it sits at 1000 revs and I dont hear a sudden change in the idle when its warm like usual. Now apart from changing the sensor is there anyway other way to check this? does someone have the resistance measurements for these things?
hey I just had a thought, what if the coolant temp sensor has been disconnected by accident? that might explain it. It would be stupid but convenient. If it is connected I will try shorting it out and see if it reacts. This will rule out the temp sensor real quick
sideshow: timing hasnt been changed, so unless the airflow meter is up the shit it rules it out.
				If you short your ecu coolant temp sensor it will should bring up fault code short to ground.
If you disconnect your sensor it should bring up fault code o/c , short to positive i would think.
1991 ST184 SX 3SGTE
1991 SW20 GT 3SGTE
2008 VDJ200 Sahara
