Hi all, I've tryed lookin with the search button for 1jz into mx83 and can't find anything usefull
what i know so far is that it can drop straight into a 91 model mx83 with JZX81 engine brackets (aluminium brackets attached to block)
A front sump configuration as i have the Jzz30 motor and box so it needs to be changed
wiring i know will have to be done
powersteering lines will have to be custom made although i read sumfin about RA supras power steering rack being perfect for the conversion (sum1 please varify this)
Thermos
use cooler and piping from a A70 supra
use 7m standard exhaust
and thats about all i can think of, if there is more parts i need or info i should know please inform me it would be greatly appreciated this is my mothers car and she needs it on the road asap hence why I'm using standard exhaust and cooler just to make it cheaper and get it on the road faster.
so all i need is a guide to what i will need to do this conversion with my spare jzz30 motor and box.
thanx people.
Ivan.
http://www.toymods.net/forums/showthread.php?t=4419Originally Posted by nemesis86
jzx81 engine mounts
front sump
custom power steer line
you can work out the rest easily enough
wire it up
