How much longer are you looking? I have aftermarket studs for a Magna, they're longer, but I don't know which ones you were talking about if they're that long.
G'day all,
i am looking for longer wheels studs.
i have ms65 hubs and original studs. i was wondering if anyone knows if different toyotas or other cars use studs with the same pitch and head etc, but different legths.
i know you can get after market ones, i went in and looked at em today. but they are way too long. i dont want to cut them down as they are never as easy to get started.
and help would be appreciated.
Stew
Heya,
i am chasing bout 6 to 10 mm longer, to better suit the rims i am using.
the aftermarket ones i found were bout 30mm longer- arp i think or something like that.
Stew
search!
these forums or the old forums has exactly this info (with pics) when i put longer studs into my ms123 rear hubs - will fit the ms65 hubs no worries. i think they were hilux
ed
../delete/ban
tech moderator
I have Nice Products replacement ones for a Magna, have a dig around, a lot of people with CrUZidas upgrade have them.
you can see the two different studs in the pic below.
i suggest reading these 3 threads:
http://forums.toymods.org.au/index.p..._view=&start=0
http://forums.toymods.org.au/index.p...eveal=&start=0
../delete/ban
tech moderator
Even if you had to cut down aftermarket ones, just get someone to taper and chamfer the ends of them a little bit with a lathe they'd be fine to get started.. or even easier if you don't want to go to that trouble, just put a nut on the stud before you cut it, file it around the edges after cutting, then when you back the nut off it again it will re-cut the thread and they'll be easy to start..
I am the sun
Originally Posted by JustCallMeFrank
Try here -> http://www.niceproducts.com.au/
http://forums.toymods.org.au/index.p...=60#msg_478535
About the 10th post down
Thanks for all the replies guys.....
i have been down to toyota, then to a wheel shop, then finally to repco...
have now found what i am after.
the studs in them are s340 -
knurl 14.1mm
length 40.2mm
the ones i have ordered are s312 -
knurl 14.3mm
length 46.1mm
the long stud listed for the s340 part is s3400 the same as is listed for the s312, so we called the manufacturer up regarding the difference in the knurl sizing and they rechon it will be fine....
by the way the long studs were around 73mm long if anyone was interested.
thanks again for your help guys.....
Stew
hey,
just a quick update,
the 14.3 knurl does fit where the 14.1mm knurl was.
it just takes alot more bashing.
i know the other size fits better because they accidently gave me one of them in my set. it was in the correct packaging to match the set i bought, but the part number stamped on the top was different.
i only noticed because of how much easier it went in!!!!
so back to repco tomorrow
Stew
FYI I have S312 on the front (as do most who have upgraded to Nissan brakes) and S315 on the rear.
Both fit fine, albeit a struggle to get them in, but then they wont come out.
Struggle to get in? I just got a wheelnut and tightened them on/in.
The fronts were no issue, the rears however...
Haha, why do you think I didn't bother.
