Results 1 to 6 of 6
Thread: AE102 -> SIlvertop conversion?
    Default AE102 -> SIlvertop conversion?
    I am trying to work out what to do with my car... I have an AE102 Seca Conquest with a 7AFE... now i want a "bit" more power... So what i am thinking about is an engine swap for a Silvertop and then swap the internals for GZE pistons to lower the compression, and then bolt on a turbo.
    For the silvertop swap, would i be better to get a halfcut or would the straight motor (which i've seen for around $550) be enough? what extra would a half cut have that would be benifical for my AE102.
    How hard would a silvertop conversion be for my car? would it be a straight bolt in? (plus ECU change to the stock silvertop ECU???)
    Default Re: AE102 -> SIlvertop conversion?
    and why not do it to the 7A block?
    is a 4A block legal in your car?
    I don't see why a 4A would not be legal? I have an AE102, the AE101 is the same car with a th 1.6L instead of the 1.8L in mine...
    I'd prefer to do a straight engine swap than to upgrade my motor
    T'ville, QLD
    what id wanna know is where are ya gonna find a silvertop for 500 bucks? i have only ever seen em about a grand without loom or ecu
    ud probably have to ditch the quads with the turbo apparently some funky stuff happens with quads and boost, or just put a 4age head on the 7a and boost that
    2T out 4A in....
    dont even contemplate STARTING an engine swap unless you have at least $2500 in your back pocket.
    ...... butt scratcher?!
    Brisbane
    Unless you already have the same motor fitted it is better to buy a half cut, you then get all the wiring brakes etc.
    Would he not be better fitting a Ae101 4agze? The ditching the super charger and turbo charging that at a later stage?
  1. MA61 - RA65 Struts & Powersteering Arms conversion
    Last Post: 04-06-2013, 09:38 PM
  2. MZ20 - 7MGTE To 1JZGTE Conversion Pics (56K Warning)
    By Danners in forum Engine & Driveline Conversions
    Last Post: 07-05-2008, 10:02 AM
  3. MA70 --> JZA70 Conversion
  4. ST162 Conversion
    By Pure-SX in forum Tech and Conversions
    Last Post: 30-01-2006, 01:34 PM
