thanks for all the replies guys.
i mentioned plug gap to adam, im running BCPR7ES with the 8mm gap as i always have, and as he recomends for everyone with a similar setup. he suggests this is not the case, and these are the plugs he ran when he had my setup.
i also thought plug gap because on some cars i have worked on with more boost, ie sr20's rb25's i have found that when the boost is upped to around 12-15psi the car missfires when the revs get above say 4000rpm, i have even closed gaps down to .6mm to fix it, but apparently this is not my issue.
ecu, old E6A.
regarding valve springs, i cannot say forsure. i bought the engine in a smashed car and it had already had the work done. i installed the engine into my car as a gze and did the rest afterwards. i have some receipts for the work done and for some of the parts, but i cannot actually confirm any of it myself. i can see that there is a metal head gasket, but thats it.
about the A/R ratio on the dyno, i can only assume this was kept in check, i would think this is the key point to the tune and any tuner worth their salt would monitor this but who am i to say. running it again on the dyno is probably not an option, its hard to get time for him to tune it let alone test it once i have checked/changed parts.
i didnt get time to get the cat out again today but im doubtful in any case. i guess ill have another chat with adam soon, im supposed to do some work on his car as payment.
