Results 1 to 11 of 11
Thread: t-18 charge light flashing
    Default t-18 charge light flashing
    hey, when i thrash the shit out of the 3t-c, the chage light flashes and sometimes stays on, this does not happen when driving slowly. only occurs when revving the motor hard..
    rooted alternator?
    other ideas...
    Stomps
    I like Cheese Backyard Mechanic Jackel's Avatar
    W.A.
    Default Re: t-18 charge light flashing
    dunno if it'll cause the problems you say but have you checked your battery clamps are fully tight?
    Previous Rides: JZA80, GA70 GT, RA63 GT x2, TA61 GT, TA63.
    Junior Member Backyard Mechanic M.J.H's Avatar
    rooted alternator?
    other ideas...
    Stomps
    Yeah I would say the alt.
    Have heard of some that will have the charge light flash now and then and the owners don't worry about it.
    Next thing they know the thing isn't working at all cause it is simply worn out and the charge light doesn't come on at all.
    Had a leco tell me that one so yeah have it checked.
    My sig has been pruned as it was over 5 lines long.
    Car Alarm Guru and Grease Monkey GTtwin's Avatar
    Torque twist pulling the engine whilst thrashing it could be pulling on the wires to the alternator. Combination of possibly worn engine mounts and dirty plug on the alternator. Worth looking into. Is it internal regulator?
    tasmania
    my corona was doing the same thing, and when i pulled apart the alternator the diode things had come off their plate and were tapping and dancing around. i tried to solder them back on but they wouldn't stick, so i had to get another alternator.
    beer me!
    My car does the same thing, i bought a brand new OEM alternator, brand new battery (old one died from running it flat too many times from this problem) and its still doing it. So i assume mine is the regulator (these are externally regulated), and i havnt even opened it to have a look yet. - so dont rule the regulator out.
    Aug 2006
    vic
    in my corona my battery kept dying and i brought a new battery and new clamps and new brushpack- and reg. and still dies. it was a fusable wire in the fuse box....... five damn dollars and i spent about 180 lol ... my guess is clamps and terminals and possible alternator, check the brush pack and regulator. If the prongs and way out the its done
    moppy: what was the fuse labled as?
    Aug 2006
    vic
    no not a fuse itself , in my fuse box it has 10 or so fuses AND two wires that are there aswell that burn out when the load is too much. they bridge the fuse box
    cheers, will have to start checking..
    cant do shit for a while coz got busy week coming up at uni..
    will start by having a look at the easy stuff..
    stomps
    ok, battery clamps tight, plug onto back of alternator tight...
    i talked to a few people bout this, most said it will be the alternator itself..
    on that note, does anyone have one they wanna sell, or if in WA i could borrow to check
    Stomps
  1. Alternator charge light not coming on?
    By WHITCHY in forum Tech and Conversions
    Last Post: 24-01-2008, 09:50 PM
  2. Inverting Alternator Charge light
    Last Post: 28-06-2006, 08:08 AM
  3. ECU error codes flashing through ABS light??
    By Alchemist in forum Tech and Conversions
    Last Post: 25-06-2006, 07:41 PM
  4. Charge light is on? Overcharging - VOLTAGE REG?
    By highrolla in forum Tech and Conversions
    Last Post: 23-04-2006, 07:53 PM
