hmm, do they make allen keys that big?
id assume you could get a bit to suit a 1/2" drive ratchet, i know you can get smaller ones. just measure the width and go shopping i guess.
Hi all..
This will be a quick and easy one for someone here...![]()
I'm tryin to get to my spark plug valley to clean the oil out
The picture supplied is looking between my 7M cam covers.
I assume I have to undo the inverted hex type nut thingo's.. But with what??
(I think there is about 3 of them in the valley from memory)
its this a Toyota specific tool? or something I can go pick up from Super Cheap or hardware store?..
or am I going about it all wrong and I don't even need to undo this![]()
+rep for those with the answers...
Damo
TRD83
ok.. my bad..
I just checked the TSRM online and found that I'm on the right track.. and that I do actually need a special tool to undo these.. or a SST as the call it..
the question still remains - where do I get it from?
Damo
Hey thats what i have to do 2moro morning! I was hopeing there was an allen key big enough in the shed. If not i'll have to dodge something up. Will let ya know
MA61 Part Numbers, Upgrades and General Infomation <--- Clicky Clicky
Try a tool shop to find an allen key that big.
Failing that, go to your local dealership and say can i please order this part number!
heres what i would do....1st find a common garden variety allen key that fits (looks like it could be 12mm across the flats) 2nd take out trusty angle grinder and chop about 40mm off the allen key...3rd insert piece into a matching size 1/2inch drive socket set...
should work fine...cheers leso
I knew it wouldn't take long..
problem solved
14mm allen key will do the job. I'll pick one up tomorrow..![]()
for reference - there is an official tool to use
http://www.cygnusx1.net/Supra/Librar...tion=C&Page=16
the last one on that page..
but who wants to use the official tool when you can just bodge something up like leso does!![]()
cheers guys...
mods - shut down thread if you like...
Damo
TRD83
Ha, 14mm hey. Well thats goodnews. Hope somewhere is open 2moro if i dont have one in the garage...
Yes, If you are sure that it isn't a core plug, like those identical looking ones on the 4AG head!I assume I have to undo the inverted hex type nut thingo's..
A bolt with that size head & vise-grips, or 2 nuts jammed for using a wrench/socket.
Kinchrome and sidchrome both make 1/2 inch drive allen keys, available at autopro/bunnings etc... IU think i paid about $8
ST185 GrpA #116
ST165 GT4 Project Car - Soon with v6 goodness.
The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
Yeah nah you don't want to undo those doobies, as allencr said they're core plugs, they shouldn't be holding anything in (besides coolant), that plate should be able to come out without removing them.
damn, i, was going to say get a bolt with the right sized head and weld a nut on the other end. Then you could use whatever on it.
Hello.
Those things arn't on there very tight, You can get away with a very wide bladed flat headed screwdriver or custome tool (or put a nut in there and put a socket over the nut sticking out.
They do indeed hold the middle cam cover in, they look the same as the ones screwed into the head underneath (those are the ones you don't need to touch)
98 3rz-fe Hilux 4x4
97 Hiace AWD Super Custom 1kz turbo diesel (sold)
87 MA70 w/ 1JZ-GTE Manual Conversion GT (moss growing on roof deteriorating away but open to offers)
like squid sed, you can get half drive allan keys that size for a reasonable price.
