Will probably depend on the box you want to use, and how that's controlled - some boxes that are computer controlled have their own dedicated ECU's, some are controlled by the engine ECU. If you're lucky enough to be able to controll the box externally, using the manula ECU should be OK, it will shift a bit harder, as the manual ECU doesn't soften the timing to allow a smoother change for the auto.
