Results 46 to 60 of 68
Thread: Introducing you to 1KD-FTV motor.
  1. #46
    Default Re: Introducing you to 1KD-FTV motor.
    Quote Originally Posted by Fish
    yeah the new turbo desiels seem to move and they don't ahve the desiel Knockl at highway speeds only on idle.
    Apparently the injector pressure is alot higher thannormal like above 1000 psi or something....
    the current toyota common rail pressure is 23,000psi approx
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
  2. #47
    Quote Originally Posted by stradlater
    Can you give the guy a LITTLE bit of a break, seriously.
    YES, he starts threads in a really bad fashion
    YES, he isn't usually COMPLETELY right in what he says
    YES, he doesn't always delineate the location of his threads correctly
    BUT,
    he IS trying
    he DOES half the time supply interesting information (I didn't know squat about those engines till now)
    he IS clearly of a different nationality and he's trying to assimilate the australian/english way of doing things / language, rather than sticking to his own.
    Give him a chance.
    Yes Stew, you do know a lot more than the rest of us, as is clear by your 'reputation' points, and it's a knowledge of the automotive domain that I am no where near close to, as are most people on here.
    This doesn't mean you have to put yourself up on a pedestal above the rest of us. Yes, you help a lot of people out, and yes you generally try to be helpful with people that you feel you can help / want to help. Doesn't give you the right to out right flame the ones you don't want to help.
    /rant.
    x2
    23132131531351315
  3. #48
  4. #49
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Actually I'm thinking of plonking one in an old Daimler...
  5. #50
    This one?
    http://cgi.ebay.com.au/1973-DAIMLER-...QQcmdZViewItem
    He'll love the concept of a truck motor.
  6. #51
    N.S.W
    I want one of These in an old crown
    Good. Fast. Cheap.
    Pick 2.
  7. #52
    Quote Originally Posted by gianttomato
    This one?
    Not quite one of those, I was thinking something from the 60s and a little bigger.
    Was a funny writeup though
  8. #53
    Quote Originally Posted by Wiggles
    Is that an old supercharged Detroit two stroke diesel?
  9. #54
    N.S.W
    Sure is! Listen to it scream
    If only it was small enough to fit into a car, the sound alone would be worth the terrible fuel economy. Too bad it'd be an environmental disaster area on wheels
    Good. Fast. Cheap.
    Pick 2.
  10. #55
    Allan, who used to post on the old forums, had a truck powered by one. Huge huge blower.
  11. #56
    Feb 2010
    singapore
    hi guys
    i have a 1KD-FTV in my toyota truck too... but i am having a load of problems with it
    the engine oil level keep rising and at a pretty fast rate too.
    it is rising by about 3-4mm after 2-3 weeks of driving (300km), and that triggers a sensor in the sump and the ecu will run into limp mode because of that.
    the only way is to drain it and top it up with fresh oil, and then it will happen all over again.
    i have teared down the engine, but cannot seem to find the point of entry of the contaminant. it has to be diesel that is entering the oiling system somewhere and causing this problem.
    would anyone have any clue where i should be looking from?
    thanks
  12. #57
    wa
    It is possible for your injector return pipe to be leaking into the cam cover area, if your injectors are leaking.
    Also it could be leaking from the injector pipes on the supply side to your cam cover.
  13. #58
    Feb 2010
    singapore
    Quote Originally Posted by 2jzhilux View Post
    i have changed all these O rings at the injectors as per picture... TWICE!
    but it didnt help
    recently after the engine tear down, it seems to get worse.. i am getting more diesel into the engine oil more frequently.
    the injector pipes on the supply side also looks rather clean... i presume you are refering to these pipes right?
    any other area that i should be looking at? a faulty pump perhaps?
    are there any other location that might leak diesel into the oil?
  14. #59
    wa
    The pipe with 23760 and the washers 23760a are where it could be entering in the first picture.
    I would be replacing that pipe and all the washers.
  15. #60
    Feb 2010
    singapore
    Thanks!
    i will look into that. i did not think that the diesel distribution from that fuel line will cause the diesel to seep into the engine oil. it didn't seem related as i would have thought at most, it will just leak out a little and not INTO the engine.
    i will try it!
  1. Which motor for the RA23??
    By o_man_ra23 in forum Tech and Conversions
    Last Post: 26-07-2006, 07:58 PM
  2. V6 4-Runner Knocking Noises in 3V-Z motor...Help Needed
    By Toyo Truck in forum Tech and Conversions
    Last Post: 05-04-2006, 09:38 AM
  3. 20v starter motor
    By Selk in forum Tech and Conversions
    Last Post: 19-12-2005, 08:08 PM
  4. Replies: 3
    Last Post: 16-10-2005, 09:32 AM
