Results 1 to 11 of 11
Thread: ra28 fuel filter help
    Junior Member Backyard Mechanic bigmat's Avatar
    sa
    Default ra28 fuel filter help
    my car is in pieces and the person before me pulled out this filter thing that had black tubing comming from it to the fuel tank. there are 4 rubber hosses leaving the fuel tank. what is this filter and do i need it.
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    Default Re: ra28 fuel filter help
    my guess is mechanical fuel pump, sits in the bay
    i just ran a lift pump for mine and didnt use the mechanical one
    hope that helps
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    livin on the edge as a Grease Monkey Snyper's Avatar
    south australia
    Sound like the Carbon Canister, does it mount on the passenger side of the engine bay, about where the strut tower is?
    if so then yeah it's needs to be hooked back up to the fuel tank, sorry I cant be more precise with what the four lines are though.
    Daily - Prado 90series
    Work - T908 620hp Cummins ISX
    Shed - 1975 TA22 2TG
    hmm i thought there wus only 3 lines for the fuel tank.
    Fuel to the bay, Fuel return and carbon canistor line.
    There will be a fuel filter (needed) connected to the Fuel to the bay line and then is connected to the mechanical pump, and fuel return shud be connected to the return of the mechanical pump. The carbon canitstor (black round thing) is connected on the carbon canistor line.
    Excited Member Grease Monkey thomasbl's Avatar
    vic
    There are 4 small lines that attach to the tank in a square pattern. these go to the charcoal canister in the side panel. The fuel filler and a breather attach close to this. There are two fuel lines which sit on top of the fuel tank, you can access them through a panel under the spare wheel. It sounds very much like the charcoal canister. have a look at the mounting points behind the panel. You will at least need to connect something to the 4 places on the tank at very least to stop leaking and forien materila going into tank. How legal you want the emissions to be in your vehicle will dictate whether you connect it or not.
    The four lines (the ones in a square pattern next to the fuel filler) go to a plastic liquid separtor.
    It is *not* a charcoal filter.
    The plastic fuel separator is simply there to make sure fuel (only vapor) from the tank doesnt flow down the vent line which runs to the charcoal canistor in the engine bay.
    [edit]
    ... and yes, you need it.
    sa
    mwp your on the money. where can i get one or find one.
    You get one from an RA28 wreck... get onto Dave Wong from Sleeka Spares (08) 8359 6446, he is in Pooraka.
    i think i still got one here mate
    Or if your down south, Toyoland may have one.
    sa
    if i cant find one here ill take you up on that offer.
  1. Ra28 Fuel tank dented. What to do?
    By thomasbl in forum Tech and Conversions
    Last Post: 14-06-2007, 03:42 PM
  2. Fuel Pump problem
    Last Post: 30-05-2007, 05:58 AM
  3. Fuel cooler / fuel temp
    By Pearce in forum Tech and Conversions
    Last Post: 12-05-2007, 07:55 PM
  4. Aftermarket engine management and injectors
    Last Post: 14-05-2006, 01:05 PM
