the easiest way to get the axles out is to get an old rim and weld the thick shaft on it...pointing in the direction of the where the axle comes out. then you get something really heavy with a hole in it tp use as a sliding weight.
when i made mine, i used a thick bolt welded to a rim with a MX83 diff housing as a sliding weight....simply slide the bolt through the diff housing (weight) put the nut on the bolt....and slide the weight out as hard as you can....3 good hits and the axle will come out
