Results 16 to 30 of 36
Thread: 1gg single turbo manifold pictures.. its built! pics added
    Junior Member Backyard Mechanic SIKTOY's Avatar
    Default Re: 1gg single turbo manifold pictures
    Quote Originally Posted by Joshstix
    Damn Jason does some nice manifold work.
    Yes Yes he does
    I'm glad you found the site useful :-)
    I"ll post more pics as I get to it
    but yes, it does get up and boogie when it does come on. :_)
    Facebook | LinkedIn
    Car Alarm Guru and Grease Monkey GTtwin's Avatar
    Quote Originally Posted by ekoston69
    Dude what turbo/manifold is that?
    As stated above, Blitz with a KKK K26.
    SCZ
    Here is another approach, middle mount turbo setup.
    Pros:Short equal lenght runners with 1.5" stainless steel tubes and collector.
    Cons: Difficult to fit on engine bay, very tight space with the chassis
    I think that Screaminrolla design is the better setup.
    Quote Originally Posted by SIKTOY
    Yes Yes he does
    Shucks, thanks fellas. I will attempt to post some more pics (at a later date, cos I am a gumby) of SIKTOY's manifold that may better show the angle of how the turbo sits. This manifold uses small diameter runners to increase the gas velocity and improve the response time, afterall we are only dealing with 330cc/cyl.
    90 Millcrest st
    Quote Originally Posted by GTtwin
    Looks identical to mine, though my turbo is a blitz k3t, hows the response on that k26?
    Quote Originally Posted by YelloRolla
    Wish I could tell ya, still not in the car.
    This shows the angle that the turbo has been placed on to make the pipe from the filter to the turbo easy.
    This shows internally how it has been stitched together.
    This design also necks down the main pipe size. The thought (as noted in my earlier post) is tto increase the velocity of the gas to the turbine. As the turbo manifold is a constant pressure system and the flow through a pipe of that diameter is quite high, and maybe even higher than the port with 2 valve heads, valve stems and valve guides in situ?
    I did make a set of pipes at this same size (1" nom bore steam pipe fittings) for a 4A GTE that made 167fwkw with slipping clutch on 17lbs.
    I know that you've already got your mandrel bends at 35mm, but it is interesting to note that tthe 1.25" nom bore fittings are approx 34.5mm (from memory) inside diameter.
    edit/ hmm links don't work???? but you can see that!
    Well thats the first decent collector I have seen in this thread.
    No wonder you do all my fabrication work Only problem with the smaller runners like that is I can't show my manly appreciation of the craftmanship
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Thanks Rod,
    i must remember to send you the reduced images next time - freak they're big.
    Love from computer gumby..
    Hoppers Crossing
    no5 looks like it has a kink in it due to the angle of the photo
    nice work there yellowrolla. as per what rod said - good looking collector work too!
    how many hours of die grinding did that take?, crikey shes a beauty, lol
    about 2 minutes - deadset. The I only die ground the flaking material off the surface. The internal welds are only fused.
    No 5 is a mirror of number 2.
    Love your work jason one day ill get the car going so we can see how it will perform
  1. **HELP** Twin turbo to single 1jz setup.
    By DLA11D in forum Tech and Conversions
    Last Post: 11-07-2011, 11:06 AM
  2. How to: Turbo Manifold design, need your thoughts
    By RAd28 in forum Tech and Conversions
    Last Post: 31-03-2009, 08:56 AM
  3. Single or Twin Turbo
    By Ashe in forum Tech and Conversions
    Last Post: 09-08-2006, 09:23 PM
  4. 1G Single turbo donor playoff
    Last Post: 23-07-2006, 04:26 PM
