Results 16 to 30 of 30
Thread: Haltech probs - guru needed - IT LIVES
    GT4 Freak, and Conversion King Squid's Avatar
    Default Re: Haltech probs - guru needed
    Quote Originally Posted by Squid
    My e6x manual reccomends going as high as 20A in some cases...
    So does the e6k manual I found on the web...
    Yeah, i was running from memory. Go with what it says in the manual.
    for ref, a peak and hold driven injector might top out around 4A per injector during the peak, but that is very short, so even if the maximum current is say.. 8x4A = 32A, the actual average current is much lower (hold around 1A).. so if you have sayy.. 1 or 2ms peak, then 10ms hold... i dunno.. it's less
    20A sounds rather high.. but if it is safe for the drivers, then why not (also depends how fast the fuse blows.. a slow blow should have no prob with the short peak..)
    The bit which reminded me is when i wanted to switch injectors i had to change the fuse over as i kept blowing it.
    Stu - im thinking that aftermarket ECU's flick over to regular PWM when you set it to high impedance injectors in the tuning software.
    It's typically low impedance injectors that need a peak and hold output..... thanks to Ohms law and shit.
    ... at least that would make sense to me?
    ahh.. i read it wrong my bad....
    youse are right
    hmm, high impedance (12ohms) pull about 1 amp each, total.. so it's easier to work out the total current needed..
    i'll go back to my hole
    Looking more and more like the drivers for some reason? They were working and i saw the damn thing running fine. Thinking best option is just to send it off to Haltec to wack on their test rig...only way i'll know for sure.
    Default Re: Haltech probs - guru needed - IT LIVES
    I'm hoping i have missed something dead simple
    Well it was pretty simple in the end...still not sure why but now sorted. I still had the stock 12v feed to the coil hooked up and it was this 12v signal that was causing all the issues...stuffed if i know ?? It did mean the pump was running full time so maybe a power draw issue?? Whatever it's running sweet on seq injection at idle and sounds tough
    Probably the voltage differential across the injector wasnt enough to trigger the switch when firing. Usually as you say due to other things running on the same line.
    Glad to hear she is running now.
    Hmmm could be Takai, nearly gave me my 1st grey hair....and that's serious.
    Dump pipe sorted tomorrow so just a bee's away from a road test.
    Far out dude, grey hairs. Sounds like you are getting old
    you forgot the wise....old and wise
    Hoppers Crossing
    wisdom hairs fellas...........
    Hmmm an update. Looks like the stock 12v ignition source was causing a problem but it wasn't the only one, just masked another intermittant fault. The 13.8v feed to the dissy also supplies the injector trigger in some way...i get a random loss of this power feed so injectors/ignition drops out. I can get ignition back by sourcing another 12v source but basically i'm going to have to strip the loom and find the dodgy section of wire/connection....ain't wiring a bitch
    Only if ur dodgy!
    j/ks mate, hope you get it sorted soon.
    I'm only online for 2 secs, so don't have a chance to read the whole post, but i'll get to it soon and see if anything obvious to me makes an appearance.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
  1. 1jz and Haltech e6k
    Last Post: 10-10-2006, 05:25 AM
  2. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 12:15 PM
  3. haltech software probs
    Last Post: 28-01-2006, 07:49 AM
  4. F Series Diff Guru needed...
    By Dylo in forum Tech and Conversions
    Last Post: 20-01-2006, 01:35 PM
  5. 3S-GTE guru needed!
    Last Post: 06-12-2005, 01:03 PM
