There is a separate on/off button somewhere, not sure of its location.
But as for the stalk,
pull towards = cancel
flick up = resume/accel
flick down = set/decel
hi I have a soarer mz20, it has what i think is a cruise control lever just on the right behind the steering wheel, although im not certain as the everything is labled in japanese, when i flick it there is not cruising to be had, does anyone know if this is the cruise control or or is it just busted if it dont work?
press the auto drive (A/D) switch until the light is on, and then you can use the stalk to control cruise control. only works above 40km/h as far as i know.
good luck!
edit: the AD button is to the right of the steering wheel... on the dash
hah yeah that makes sense cos thats just that a/d button is busted
thanks
My cruise control also doesn't work, but by the look of it, some of the stuff might be missing under the bonnet. There appears to be a vacuum pump, but I can't see how it controls the throttle.
Can someone post an annotated photo or similar so that I can see what is missing? (I guess even a description of the parts would help.)
Also, does anyone know where you can get an MZ20 steering boss which lets you keep cruise control?
