Results 1 to 3 of 3
Thread: st-162 fault codes
    New South Wales
    Default st-162 fault codes
    hi guys,
    my celica used to give me code 21 (o2 sensor) on occasion. i replaced that and now im getting in succesion (right after each other) code 25 then 26 or lean mixture then rich mixture.
    i cant figure out whats causing this. i put a brand new k and n panel in so its not that. ive run some injector cleaner through a couple of times. btw the car still drives perfectly with no power loss or anything, smooth as.
    im out of ideas, so throw some my way
    thanks in advance for any help
    regards,
    john
    Default Re: st-162 fault codes
    After you replaced the o2 sensor, and air filter did you reset the ecu?
    If not, you need to pull the efi fuse out for a few seconds to reset it.After that, then check for codes. hopefully you fixed the problem.
    New South Wales
    ill give it a go
  1. ECU error codes flashing through ABS light??
    By Alchemist in forum Tech and Conversions
    Last Post: 25-06-2006, 07:41 PM
  2. 7M Fault codes
    By RONA in forum Tech and Conversions
    Last Post: 19-04-2006, 08:42 PM
  3. 20V fault codes
    Last Post: 08-01-2006, 11:31 PM
  4. Toyota Diff Codes Explained
    By TheToyman75 in forum FAQ
    Last Post: 21-10-2005, 01:56 PM
  5. Toyota Model Codes Explained
    By wagonist in forum FAQ
    Last Post: 14-10-2005, 09:47 PM
