Results 16 to 22 of 22
Thread: Davies Craig EWP - Opinions?
    Default Re: Davies Craig EWP - Opinions?
    I've taken mine out for a drive a couple of times today and so far it's been flawless.
    The car gets up to temp quickly, then never budges. It's about 33 degrees here today. I haven't driven for very long yet, but I'm impressed so far.
    so it goes striaght in a 4age or do u need a kit or sumthin
    Sideways since 1984 Backyard Mechanic ToySprinta's Avatar
    just put it in the bottom radiator hose, remove thermostat, remove pump impellor, insert thermo probe in top hole, and wire up controller and pump.
    ie universal fitting
    Steve - Sideways since 1984
    AE86 - Worlds first Aurion 2GR-FE conversion into a hachi
    ED Fairmont 5.0L - Luxury Towing
    EBII XR6 - Temporary drift piggy
    It takes some buggering around to get a neat job, I cut the whole nose off the water pump so I could get better belt wrap for the supercharger.
    I took it out for a drive yesterday assuming that 40+ temperatures and a ZE should be an interesting experiment and the temperature didn't move - Very impressed.
    If you want one, talk to Dale (10sec_rx7) about his thermostat mounts, they are much better than the factory setup (and what I came up with).
    Quote Originally Posted by Ben Wilson
    And did the temperature move with the factory pump?
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    I was at repco (Rip Every Poor **** Off) some time last year, looking for a new waterpump. The guy tried to sell me a EWP instead of a normal mechanical item... went and bought the toyota item for cheaper later that day
    Well - It did when the standard pump failed
  1. Possible 7M BHG... opinions please
    By whatthe? in forum Tech and Conversions
    Last Post: 30-12-2005, 06:05 PM
