I had help with that conversion however.. and the engine was ma61 ready.... but it's possible with preperation.Originally Posted by RObErT_RaTh
I don't think the 7m-ge is significantly harder... the wiring would be slightly more involved, but thats not too hard to sort out. Exhaust stuff/engine mounts/gearbox/etc would be the same. Power steering, is that on the same side?
Well, the engine is out and there, you could always get started straight away![]()
I've never done a conversion before and from what I've been asking and reading it will be harder than a 5MGE and I don't think I could personally do it.Originally Posted by JustCallMeFrank
lumpy, lol at the oil![]()
5me-5mge is a piece of piss conversion. its bolt out bolt in basically. just need a new p/s hose made up and a few other bits and thats about it. theres not much to it. easy weekend swap. but i agree with what others have said...save your money.
do the 2j, sure its a little bit more complicated but take your time and there is no reason why you cant do it yourself.
I have a Crown
Power steering hose and a few other bits? Care to elaborate on the few other bits?
I know I need the throttle cable from the MX73 because the MA61 is a tad too short I believe.
Dude. 7mgeYou doing something at TAFE regarding electronics or wiring aren't ya? I have no knowledge whatsoever at wiring. Ask James (Viper_Nipplex). I compeltely and utterly suck at it so much, I actually almost set my car on fire. But it took me 3 hours to wire the 7mgte up
Mechanical wise, it should be pretty much bolt in I would say? MX83 7mge front sumped?
SHE LIVES!
Yes they are front sumpedI used to do electronics at TAFE but it's the whole mechanical side of things I think I might struggle with a bit. For example on the 5MGE gen II's I will need to somehow get a mechanical dizzy to work with that. I have no idea how I'm supposed to hook my 5me dizzy upto the 5mge. And this is supposed to be the easy conversion, there are no doubt harder unforseen things I would have to do with a 7MGE swap.
The 7MGE was only going to be done because someone else was going to do it for me. Now that's not happening I have to do this myself and I just don't want to spend all the time and money on a 7MGE then find out I can't do it and I won't have anyone to help me put it in
Lots of people on the old toymods forums did the conversion with success and that's why I want to try it. If it falls through I haven't lost much money but with a 7MGE it could be a lot more money wasted if I fail.
Mechanically with a 7mge, being front sumped, would be dead set easy. Take out 5me, put 5me engine mounts on 7mge, and put 7mge in.
Getting the air con and power steering to line up and work may take a curse or 2, but all in all shouldn't be too hard. I was lazy. I piffed my air con in the bin.
SHE LIVES!
If you are able to do a 5mge swap you are going to be able to do a 7mge swap, especialy in a month.
regards
jon
regardless of your M series engine, don't forget to set aside money for new head bolts and a MHG
.... here we go again. I am unsure if I will even be able to complete this swap! If I can't do it, I've wasted well under a grand with a 5MGE. If I try and fail with a 7MGE that's a lot more money spent on my part and I can't risk for it all to be a waste. I'm doing the 5MGE, nothing now is going to change me to the 7MGE at the current point in time with money and time restraints. And this is a month of working a couple hours each night during the week. I work full time.Originally Posted by jonra23
Can I just get some responses now from people that have done the swap and have any detailed tips/pointers on exactly what needs to be done? Thankyou
NotedOriginally Posted by Draven
Dude, i would be more than happy to give you a hand if you get stuck with the 7M conversion. It will be mch easier to do on a budget over the 2J mainly due to the extra cost of the bellhousing for the 2J.
Im sure Joel and Jesse would also give you a hand. It seriously wouldnt be hard at all. Im even guessing that the ECU will have all the markings on ithe PCB for the pinouts, at which point its a piece of cake.
As for costings, if you go with Jesse's motor, even at the $500 asking price I cant see it being over a grand for it to be in.
The only hiccups i could see would be $190+60 for ARP studs and headgasket, and maybe $250 for a new clutch if you need one (youll know now if you do).
The new PS line for them will have to be made up for either the 7MGE or the 5MGE as they have the PS in the same spot from memory. AC is exactly the same, and you will need to regas either way if you are going to keep it.
To get away from a regas on AC, remove AC compressor from motor whilst still in car without disconnecting hoses, zippy tie to chassis, do do motor swap and then refit ac compressor to new motor.
regards
jon
Clutch is fine, had it replaced not that long ago and now I have an 'extreme' brand heavy duty in there. Another advantage of the 5MGE I see is that if I do change my mind later down the track (which is probably what will happen) I can still turbo it without too much hassle whereas the 7MGE can't be turbo'd that successfully.
Call me stupid, close minded, stubborn whatever but this is what I want to do. I know I won't be getting heaps of power increase but it will still be enough for me.
