the struts dont go in without a lot of fabrication, including the use of the superstrut subframe and the addition of mounts to the AE9x chassis etc. The AE101 superstrut setup doesn't even bolt into an ADM AE101.
If you're talking about brakes then it's a totally different story. Get yourself a set of 258-260m diameter discs, 25mm wide with the 54mm center hole and 4x100 pattern, clearance the caliper slightly and bolt it all up.
