What sort of jack dude? The scissor jack thingo that comes with the car? Or a trolley jack?
Ey guys,
As the title sugest i'm wondering whereabouts the correct place to jack my MZ21 is? It appears to have been jacked many, many times in the past, from many diferent locations all of which have left there markI'd like to knwo where abouts i should really be jacking from, to prevent anymore damage being done to the underside of this car.
Cheers guys,
Ashlin.
SHE LIVES!
either, i've been using a trolley but think the standard jack would make getting the jack stands under easier
Well scissor jack points are located behind the front wheel and infront of the rear wheels kinda next to the chassis rail. Should be indentations that shows you the 'correct' position to place the scissor jack.
With the trolley jack, I just normally put it under the cross member in the front and under the diff at the back. I dont think there are really a correct place to place a trolley jack, as long as the place in question can support the weight.
SHE LIVES!
I do what Yian said above with my MZ21
600 Club Member: Toymods Large Member
MegaP00 - 7MGTE Skunkworks division
RIP - Nathan Dean (TA-022)
What Yian said is right. If you're having trouble getting the jack under there in the first place, one option is to either use a couple of planks, or do what I did and make some little ramps out of wood to drive the car up onto first, leaving plenty of room to jack even when the car is lowered.
If you dont have enough room to roll the car onto the bits of wood you can jack off the front tow points to get the bits of wood under.
