Results 1 to 4 of 4
Thread: PCB board ground question
    Default PCB board ground question
    On a PCB board, the lighter green area of the board on the top, is this used to ground components?
    Certain components are isolated from it, while other areas have little joiners to it?
    I hope this made some sense......
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    Default Re: PCB board ground question
    Depends! Is it double sided? Is it really a copper/brass plane or is it just the silk screening?
    If it is a copper/brass plane, it doesnt have to be a negitive! Could be positive!
    Junior Member Domestic Engineer tricky's Avatar
    PCB (printed circuit board) Board = tautology
    The green stuff is an anti-corrosion coating, and it's non-conductive (electrically). The lighter green colour is probably a bus, ie a large track on the board. These are often a common point, so they can be a ground, a +vin or anything else that is common to several components. So in short... There are no gaurantees it is a ground, although with some closer inspections you can figure it out by the polarities of connected components, the pins of IC's connected to it etc.
    hope that helped, but I fear not
    Thanks guys.
    Searched one of the semiconducter serial numbers and found a pinout.
    The light green was indeed a bus for the ground circuit.
    Last Post: 17-06-2008, 08:53 PM
  2. ae86 / ke70 comparison question
    By BeRad in forum Tech and Conversions
    Last Post: 14-12-2005, 06:59 PM
  3. question for the board about selling items
    By EVOSTi in forum Toymods Car Club Membership and Feedback
    Last Post: 19-09-2005, 04:17 PM
