Well I've done it. Fully variable intermittent wipers for a MK1 MR2. Today was a great opportunity to test it too in Vancouver's drizzly rain. If you can solder and have the patience of a monk, you too can have this indespensable feature on your 2.
If you use the same components that I used, you'll be able to vary the frequency of your wipers from half a second (faster than current speed), to "Is this still on?" I timed it to 5 minutes, and still it didn't sweep. So it's likely somewhere over 5 minutes but (hopefully) less than 10. I'll edit this message when I know how long.
Here's what you need...
- 1Mohm, linear taper, 1/2W potentiometer (AKA: pot - don't get excited). $2.00
- 24Kohm, 1/4W, 5% resistor. $0.25 (but might have to buy more than one)
- knob for the pot, suitable to your tastes. $2.00 depending on taste
- 8" of 24-22GA stranded wire. (cheap)
- These instructions and accompanying pictures. (FREE!)
How does it work?
Inside the wiper switch assembly, there is a small printed circuit board. This board is exclusively for the intermittent setting of the wiper switch. The timing circuit is a standard R/C network and a couple of transistors to drive the relay.
To change the speed from the preset to variable, simply replace R1 (91Kohm, 1/8W, 5%) with a pot. The extra 24Kohm resistor is so that when the pot is adjusted to 0 ohms, the circuit is not completely shorted out, you can vary this resistor from about 20Kohm to 100Kohm. This resistor will determine the fastest speed setting.
I used a 1Mohm pot, but the slowest setting is well over 5 minutes (still don't know what the slowest is exactly). If you feel that's too long, try a 500Kohm pot, but I don't know what the slowest setting would be. The type of pot you use will determine where you place it. Mine was part # 62-229-1 from RP Electronics in Burnaby. It was the smallest one available, because I wanted to fit mine inside the existing switch assembly. It also came with a switch, which I cut out (see pics G & H).
If you decide to put your pot somewhere else, you'll need more wire, and maybe a connector so that you can disconnect it in the future for servicing other parts of your dashboard.
Polarity is irrelevant here so don't worry about it. The only thing to be careful about with the wiring, is direction of the pot from fastest to slowest. Use an ohmmeter to test which way you want it to go. I set mine so that the fastest speed (lowest resistance) is full counter-clockwise (see pic J). If you want the opposite direction, just reverse your connections at the pot.
Here's how to do it...
- Read through these instructions and look at the pictures first as I included techie-tips on my experiences.
- Disassemble the dashboard area that houses the wiper switch.
- Remove the wiper switch from the housing (see pic A).
- Remove the one screw at the top of the switch (see pic B).
- Pry up on the sides, in the middle of the top cover of the plastic case on the switch, until the two tabs at the front of the switch let go.
- Gently pry up the circuit board the same way as the plastic cover.
- Locate R1 (91Kohm, 1/8W, 5%) in the middle of the board (see pic c & D). Unsolder R1 and discard it (see pic E).
- Cut your 8" of wire in half.
- Solder both wires to the pot (see pic J)
- Solder the free pin of the pot to the center pin. If you know electronics, you'll know why. If not, just do it anyhow.
- Mount the pot to the switch housing (some measuring involved here, you'll drill a 9/32" hole in the side of the switch, make sure of the position, you only have one shot at doing it right (see pic K).
- Just finger tighten the nut on the pot for now. Run the wires under the shaft of the existing switch. (see pic K).
- Solder one of the wires to one of the holes of R1. (see pic L)
- Solder the other wire to one end of the 24Kohm resistor.
- Solder the 24Kohm resistor to the other hole of R1.
- Electrically, you're done.
- Test fit the board to make sure it doesn't pinch the wires or the resistor as you close the case (see pic M). Leave the top of the switch open for now.
- Prepare the housing for the switch. Measure the area to be drilled for another 9/32" hole. Again like the first hole, make sure of the position, you only have one shot at doing it right (see pic N). I realize this is repeated, but measuring out before drilling is extremely important!
- Mount the modified switch into the dash housing. This part is easier said than done! A lot of expletives and one wasted pot (good thing I bought two), before I had it installed in the housing (see pic N). TIP...remember when I said to finger tighten the nut for the pot? Now loosen it completely, but keep the nut/washer on the shaft of the pot. Also remember when I said to leave the top of the switch open? This will help when you retighten the nut on the pot.
- Line up the assembly into the housing, the loose pot and your accurate measurements will help. Once in place, put the nut on the front of the switch, but leave it loose. This will help when you tighten the pot down, between the switch housing and the dash housing. Check the inside of the switch to make sure that as you're tightening the pot, it isn't rotating on the inside. Once it's tightened, then check the wires and pot, to make sure that they aren't "stressed". Close the case of the switch (have fun with the screw). Tighten the front of the switch.
- Re-assemble the dashboard (see pics P & Q)
NOTES:
I started this project late yesterday, but needed my car to get parts this morning. So I had to re-assemble everything (partially, see pic F). Make sure you have all the parts in advance, and give yourself about a day to complete this task. You have the benefit of knowing which resistor to pull out, something that took me about two hours to figure out. I wanted to make my pot fit inside the switch housing, to make it look cleaner on the dashboard. If you want to avoid some headaches, consider placing the pot somewhere else on the dash.
Pete
