That pipe won't have a valve in it, there should be another pipe connected to your plenum that will have a valve in it (same as the 1J). When your throttle is closed & a vacuum exists in the plenum this will suck the oily gases into the plenum through the valve, as the throttle opens & the vacuum dissapears (and is replaced by boost) the valve will close & the crank case will breath through the pipe going to in front of your turbo.
How much oil are we talking here? Unless there's alot of oil, as in enough to notice your oil level going down over time, don't worry about it too much. If you want hook up a catch can in between the cam cover & turbo inlet so you can see exactly how much your losing out that side.
