if the a/f is fine it shouldnt be running lean... how did you test the a/f
is the whole end of the plug white? white doesnt just mean lean..
bits of white on the plugs can mean preignition meaning the timing is advanced to much, or that the plug isnt rated for the right heat range for your engine, lack of engine cooling may also cause it.
white sought of spots sometimes mean detonation....
is it white or an ash deposit, if its that valve guide seals may be worn etc....
and are you sure your gapping them right to the engines requirments... usualy if there for the engine there not to far off being what they should be...
