Results 1 to 15 of 19
Thread: 1G-GTE Fuel Efficiency and RA28 Rear Seats
    Default 1G-GTE Fuel Efficiency and RA28 Rear Seats
    Hey all,
    Just would like to know what L/100km people are getting in a 1st gen celica (or equivalent) with a 1G-GTE...
    Also, do the rear seats in the RA28 fold down?
    Default Re: 1G-GTE Fuel Efficiency and RA28 Rear Seats
    RA28 rear seats do fold down.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    10km per litre from my old 1G-GTE.
    cheers Chuck.
    MS51Crown Coupe,
    I get around 9.5-10.5l/100km in my heavier car with modified 1G. I think you'd be able to beat that.
    Quote Originally Posted by ChuckLandwehr
    cheers Chuck.
    Expensive to run!?
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    Touch my Grease Monkey Chow's Avatar
    I wouldn't say that 10km/litre was expensive to run, when you'd be lucky to get that from a new Commodore, and it wouldn't be nearly as fun to drive. Anyway, fuel economy has a LOT to do with the way you drive. Spirited driving equals spirited fuel consumption. Granny driving means less fuel used. Personally I think using slightly more fuel to have more fun in my car is worth it.
    10km/litre (or 10l/100km) is not expensive! (It's not as cheap as an Echo, but what would you rather drive)
    I drive (granny) a BA MKII XR6 Ute as my daily and average between 11.5 and 12l/100km combined.
    I would definately say that having a light car, with a great range of power and torque, only using 10l/100km (or less) is not expensive!!!
    West Australia
    from 60L in my semi-stock 1GGTE @ ~12PSI i get around 450-500kms (180,000 kms on the clock)
    from 60L in my 1GGTE with single CT26 and other mods, i get around 400kms (130,000kms on the clock)
    When you say that John, are you saying when you fill up? Or are you actually putting in 60L?
    Quote Originally Posted by twentyEight
    Exactly..i find it amazing how an engine like that can get good economy and yet, still be turbocharged and have a great band of power...compared to, as you say, a Ford or Holden 6, which has a limited band of power and guzzles like theres no tomorrow..and its naturally aspirated!
    Kind Regards,
    Kurt.
    Turbos only supply more air to the engine when needed.
    If you drive a NA car then the same car/engine turboed at exactly the same speed, accel, etc, the turbo will only use slightly more fuel.
    West Australia
    Quote Originally Posted by JustCallMeFrank
    yes nathan i am indeed
    So in reality you're not using the full 60L to a do those km's?
    And a heavier car? *guess*
    RM.
    I Have done almost 700km from a full tank of juice with my stock 1ggte in an RA28, this was all highway driving though. City I use more but I do like giving it a bit quite often.
    Hello.
