Results 1 to 15 of 15
Thread: TA22 Brake booster and MC
    Default TA22 Brake booster and MC
    G'day guys
    Im wondering what people have done with there booster and MC combos on there TA22s, i have a RA booster and 1"Mc that i can "make" fit but before i start i was wondering if there are any other options? what have others tryed? whats worked? what hasnt?
    Hoppers Crossing
    Default Re: TA22 Brake booster and MC
    i used the stock booster and a mitsu triton/pajero master cylinder. goes together perfectly, no issues at all.
    what size is the MC?
    Hoppers Crossing
    i think its a 1"
    merc-blue
    Stick with the standard TA-22 booster, then will not have to try fitting the bigger size RA booster which I believe physically will not fit in the space the old one came from.
    As long as the TA-22 booster is in good order then it need not be an issue when doing a brake upgrade.
    I use an MC that comes from an ST205 or try a late model (1999-2002) Camry. Both bolt up but check the resivour will clear the vacuum hose port. I believe there is an angled port fitting to clear for the booster but not sure what it is out of, but is also a straight swap.
    Both MCs are dual circuit, 1 inch and alloy with outlets on the engine side.
    Regards
    Rodger
    Hoppers Crossing
    if you want pics of my setup let me know.
    Hoppers Crossing
    never mind
    sorry about the size
    i had to remake the pipe that goes to the union for the front and the rear brake bias thingo - just a bit of bundy tube did that job perfect. braided would be better and look nicer
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    mate i also use the stock TA22 booster and MC from a 205 GT4... the GT4 is 15/16" and mounts great... i didnt go for the 1" as it is only 2mm bigger BIG WHOOP...
    the only issue with the GT4 way is as mentioned above, the breather hose cannot be put back on as the MC is in the way... i resolved this by using the plug from the GT4 booster... the TA22 plug sticks straight out, whereas the GT4 is at a 90deg angle which slots in perfectly... cant show pics as the car is in pieces...
    also the GT4 MC has the brake fluid sensor if you wanted to hook that up aswell... i might do that, but still not decided...
    Grega,
    What yr triton/pajero MC have you used? I am thinkin of hitting the local wreckers this weekend to find one and a model/yr would be fantastic!!
    Regards,
    Rob
    Junior Member Backyard Mechanic kugzs's Avatar
    i would rep you grega but ....
    Hoppers Crossing
    rob i'm not sure actually. can't remember.
    i'll see if i can find out.
    credit for the MC goes to fookstar - 100% rep for him
    Hoppers Crossing
    was wrong. its 15/16" not 1". sorry for the bum steer
    anyway more info here
    http://forums.toymods.org.au/index.p...t=0#msg_231301
    Quote Originally Posted by Rodger
    deffently dont fit, but a hammer and dolly can fix that,
    im gonna see if i can get a 15/16th from a ST205 or similar first
    grease monkey Grease Monkey
    Hey
    I have stuck with the TA22 booster but had it internally re-kitted and modified to suit a 1" master cylinder off something. Because i had clearance issues fitting a big M/C with my 3TGTEU i had to have a M/C that was really narrow, so i just looked through a catalouge at the local brakemart and found something suitable and now it all goes together and works really well. I can find out the Part number of the M/C i used if anyone is interested, cost me around 400 to have everything done.
    part number would be good mate.
  1. Brake booster and master cylinder KE30
    By shy_77c in forum Tech and Conversions
    Last Post: 31-05-2006, 05:18 PM
  2. Removing brake booster, for race?
    By Jonny Rochester in forum Tech and Conversions
    Last Post: 10-01-2006, 09:26 PM
  3. 20V Brake Booster Vacuum Problems
    By ShiRi in forum Tech and Conversions
    Last Post: 15-12-2005, 07:06 PM
