no one knows?
basically, if anyone has a 4AGE setup in their car, tell me what your ECU part number is and what color your injectors are (only on bigport setups please)
thanks all in anticipation![]()
Hey
Been doing some searching and have found heaps of info on injectors, flow rate, impedance ect ect blah blah
However, which injectors (specifically bigport 4AGE) suit which ECU?
I have an ECU here, its 89661-14061.
I have a loom I'm putting together to suit.
How can I tell what impedance injectors the ECU is expecting to see? Theres high and low impedance injectors for the 4AGE (pink and grey types).
Is there any hard and fast list (or am I about to compile one?) to say that this ECU part number goes with these injectors?
Hope someone can help![]()
no one knows?
Hey Grega,
Just flicked through the EPC and you have an ecu to suit an AT141 or an AA63... both of which run 4ageus... strangely, the jap AE86 which should run the same engine has a different ECU part number?
Anyways, after crossmatching the the injector numbers, they use the same AE86 ones so you'll be looking at the grey plugged, low impedance, 180cc injectors for your ECU. Good luck with it!
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
+1 million rep for you. many, many many thanks eddie.
