Taken straight from my celica workshop manual![]()
Brake bleeding should commence at the wheel cylinder furthest away from the master cylinder. Attach a flexible tube of a good fit to the wheel cylinder bleeding plug and put the other end of the tube into a bottle already filled with brake fluid. Pump the pedal several times and then hold the brake pedal in the down position whilst the bleeding plug is opened and closed as the old brake fluid starts to flow out. Carry out this operation three or four times on each wheel until only brake fluid and no air shows out through the pipe. Repeat this operation for each wheel finishing with the wheel cylinder nearest the brake master cylinder. Ensure that the master cylinder reservoir is kept topped up at all times during this operation or further air will enter the system.
there was absoloutely no air coming out of the lines... hrmmm ideas?
