Results 1 to 8 of 8
Thread: 3sgte Front mount distributor
    Jun 2006
    Default 3sgte Front mount distributor
    Have seen mentioned a few times mounting the distributor on the front of a 3sgte when converting to RWD, have searched and can't find any detail or pics.
    Does anyone have pics, experience, hints with this mod as I am in process of doing same with 2vz-fe for a rwd setup.
    jon
    Welcome to the Darkside! Automotive Encyclopaedia -==L=a=N=c=E==-'s Avatar
    Rosewood
    Default Re: 3sgte Front mount distributor
    Best person to ask would be TerryO, he recently finished this type of conversion on a customers 3SGE.
    The Supreme Backyard Mechanic
    very interested to know also
    There is quite a few 4age 20v with this setup. Might be worth researching that and try to apply the same design/ideas to a 3S.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Or you can get rid of the Dizzy all together and use a trigger wheel with Aftermarket ECU.
    Yeah that would be prefered option
    Jun 2006
    Thanks guys.
    Am in process of doing rwd conversion on a 2vz into a RA23, engineer that have been talking to wants original engine management in place for roadworthy, will probably then go to something a bit more tuneable with wasted spark/MAP sensor etc.
    Have a few sketches of what i recon will work properly, was realy after some pics to see if there is anything i can do easier.
    Am guessing as others have done similar with other motors that dissy produces adequate pulse strength running backwards, cant see why it wouldn't.
    regards
    jon
    In a 4A dizzy for example the internal teeth on the gears are straight so I don't think it would matter what way it spins. But cannot comment on 2vz sorry.
  1. Legality of cutting front to mount intercooler..
    By d-shiznit in forum Tech and Conversions
    Last Post: 21-12-2005, 11:15 PM
