Well it looks like it's something common to most of your electrics.
Do the lights come on strong?
The cold affects the capacity of the battery. So I assume the battery is okay - but if it's not been charging well and shit like that then it could of been flattened too much and therefore won't hold a charge. If this is the case you'll need a new battery.
Failing that. remove the battery clamps and clean up the terminals and put the clmaps back on. Unplug, clean and reconnect the fusible link (comes off the +ve post of the battery).
Search for the big ground wire from the -ve clamps of the battery and see where it conencts to the chassis/engine. Unbolt it from this anchor point. clean up the area and bolt it back up. Hopefully that will get you out of trouble.
seeyuzz
river
