Results 1 to 15 of 22
Thread: Quick ques: using cable ties in fuel?
    Default Quick ques: using cable ties in fuel?
    Im fitted my new walbro fuel pump. to secure it to the OE pump bracket can i use ordinary plastic cable ties? they dont have the metal lock clip on them. just plastic. will it be ok?
    Its an intake pump btw.
    thanks in advance
    Default Re: Quick ques: using cable ties in fuel?
    They might work, but I'd use hose clamps...
    just got the old pump out. it had a cable tie round the bottom holding it...
    Ghetto Goodness Automotive Encyclopaedia Ghetto-AW11's Avatar
    For the price of a hoseclamp, I wouldnt even bother worrying if a cable tie will work.
    Homebrew, triumph triple, turbo aw11
    Junior Member Backyard Mechanic Supra-Jim's Avatar
    Bluetack!!!!!!!!!!!!! FTW!!!
    But seriously as said earlier, for the low cost and lack of hassle, use a hose clip
    They call them fingers.... but i've never seen them fing!!!!
    has no Toyota anymore :( Conversion King tooch's Avatar
    Get some good quality SS hose clamps so they don't rust (if they rust in fuel anyway?), don't use the rubbish cheap ones, they will probably loosen off over time from the vibrations.
    Im not sure if its been mentioned or not...
    use a hose clamp instead
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    This is what people are talking about:
    It's a hose clamp in case anyone was wondering.
    My KE25 thread
    Roll Ons? Carport Converter Endless's Avatar
    Hose clamps... the new age cable ties!
    As others have said I'd use a hose clamp.
    BUT as an indication, the fuel pump that I pulled out of my MA61 was held in with zip ties. And it had been in there at least a year (and I suspect much longer). The zip ties still appeared as good as new....
    My only concern with zip ties is that we all know you can get cheap shite ones and decent ones. The cheap ones tend to break easily, have a poor locking mechanism etc.
    But recently a decent brand that I have never had trouble with before had some duds in the packet, the only way I noticed it was a few hours after using them they had come undone a few cm . They felt as good as the others to do up but the "ratcheting tooth" had no bite. I would hate to see the consequences of something like this happening on an item not easily seen/checked.
    So yeah, hose clamp FTW!
    My KE25 thread
    both my walbro kits came WITH cable ties
    they were a kinda of semitranslucent white one tho, nbot the usual black or white, so it is possible that they are a fuel resistant type.... so they are SUPPLIED with cable ties (albeit maybe a special type)
    so unless you are sure your cableties are fuel resistant.... use hose clamp
    so unless you are sure your hoseclamps are fuel resistant.... use hose clamp
    You mean zipties
    My KE25 thread
    i got distracted by my professor asking about the diffusion depth of platinum after 500hrs oxidation whilst editing
    but I read........
    i got distracted when my lollipop got stuck to my tracksuit pants whilst editing
    My KE25 thread
  1. Replies: 24
    Last Post: 18-04-2006, 02:42 PM
  2. ra23/ra28 linkage to cable for 18rgu
    By krohla-10 in forum Tech and Conversions
    Last Post: 29-03-2006, 01:45 PM
  3. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 09:14 PM
  4. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
