Results 1 to 8 of 8
Thread: Rims redrilled
    Default Rims redrilled
    I have been talking to a mate who wants to get some rims redrilled from 4x100 to 4x110 but doesnt want the old holes to be visable any way to get this done?
    Rohan
    Default Re: Rims redrilled
    Chris neal at Wheel Revolution in QLD can do that, he can do all sorts of rim modification and repair.
    so these guys can also fill the old holes casue they normaly redill tham 90 dgrees around from the old stud patten
    yep, that's what I confirmed above.
    Here's a rim he modified the PCD on, the owner didn't want all the holes filled in this one...
    http://www.twincam.org/forums/upload...1153961423.jpg
    And here's Chris himself at work on one of his old machines:
    http://www.twincam.org/forums/upload...1153961397.jpg
    Cheers, i know a few guys who might be able to do it down in melb
    You'll have to make sure that if your changing from 5 to 4 stud or vice versa that the wheels can actually be drilled to suit that stud pattern as alot of wheels cant as the hub mounting surface contains recessed bits. They will only be able to be drilled provididing these recessed bits don't line up with the intended bolt holes.
    - LeeRoy
    Junior Member Backyard Mechanic haison's Avatar
    Hey can you let us know how much it ended up being and where you did it once it's all done?
    Penrith BC
    i wouldnt weld the holes closed
    ../delete/ban
    tech moderator
