Auuming the 18RG electronic dizzy is a fully locked jigger with a reluctor, it's fairly simple. The only tricky bit is getting the reluctor polarity right. Get an analog multimeter, put it on its lowest voltage setting across the reluctor outputs then turn in slowly in the direction of normal rotation. If the needle moves up, then down the polarity is right. Otherwise you'll need to reverse the wires.
That section of the manual isn't too bad IIRC.
