Results 1 to 6 of 6
Thread: Lubricating the 4K Electronic Distributor
    Selangor
    Default Lubricating the 4K Electronic Distributor
    I wondeer what one should use to lubricate the internals
    (centrifugal advance, etc ) of the Nippondenso
    electronic distributor for the 4K ?
    Would spray lubes like WD40 do ?
    This dizzy doesn't appear to have any lube holes
    in the housing.
    Default Re: Lubricating the 4K Electronic Distributor
    bearing grease!!
    though i've seen normal grease in it.. probably dodgy mechanics? ..
    Junior Member Domestic Engineer tricky's Avatar
    I use machine oil in dizzys. A couple of drops are all that is required, and it doesn't attract dust the way grease does. My gummed up 18RGEU dizzy was gummed up due to copious amounts of grease bound to dirt and muck. If you have it in pieces, use a tiny bit of grease on all moving surfaces before you reassemble it, but wipe the excess clean.
    Nikita the RA23 is almost finished .
    Selangor
    Thanks, Vios and Tricky.
    Can silicone spray be used too, especially on the breaker plate
    to help the vacuum advance shift it smoothly ?
    Emo Slayer Backyard Mechanic rollin_stock's Avatar
    South Aust
    Never, i repeat, never spray stuff inside your dizzy unless to clean it out when in peices. Points (not in your case but for others) and dizzy cap are to be kept dry too.
    You always see people (my ignorant mate) spray the inside of the dizzy and cap with WD40 'just to be sure'. This spray will help burnout your points, if you have them, rotor button and cap until you buy new ones and spray more Wd40 in 'just to be sure'.
    keep it dry!
    Selangor
    Thanks, Rollin'.
    Will keep that in mind.
  1. Electronic Distributor for 4K Engine
    By Tham in forum Tech and Conversions
    Last Post: 20-07-2006, 09:25 PM
  2. how to lock a distributor?
    By CHB in forum Tech and Conversions
    Last Post: 14-06-2006, 12:46 PM
  3. 3S-GTE Distributor o-ring
    By Matty P in forum Tech and Conversions
    Last Post: 22-03-2006, 09:27 PM
