Results 46 to 60 of 68
Thread: SDMA Hillclimb 27th May 2012
  1. #46
    Nov 2011
    Default Re: SDMA Hillclimb 27th May 2012
    Front camber plates arrived and installed (thank god for rattleguns). Set for max caster, confusing eh? So Supersprint is looking good.
    I have my camber plates set for max caster instead of camber.
    Did you happen to find that deep dish steering wheel?
  2. #47
    Sep 2008
    Yay bom has updated the forecast for sunday to cloudy instead of rainy! I have some newish 595s fitted to rims anyway in case of rain, but hopefully will be able to give the slicks a decent run
    Nissan Silvia S13- 1UZFE
  3. #48
    Depending how I feel on Sunday morning, i might come by for the short drive to WP to see you guys, rather than continuing on to Sydney for the cruise
    If not, good luck to all!
  4. #49
    Quote Originally Posted by Tyrie View Post
    How did the new tyres go at Texi? And I need to sort a set of 595s for wet weather.
    Weather is looking slightly better for Sunday - will be cold at Sutton, but I'm sure Wakefield will be lovely (and ken freezing as always).
    Good luck to all at the Sprint.
    79 Series 1 RX7 - 13b PP N/A
    Low(ish) budget track hack - hates trees
    SDMA Hillclimb: 47.03 - Class record holder for Type 3 2001-3000cc
  5. #50
    Sep 2008
    Didnt get the hankooks very hot but they seemed good. All the people running them in the states seem to run them at 37-38psi, I had them at 32. Will try for higher temps on sunday.
  6. #51
    I can't find a tyre shop that can actually fit my slicks I have two on and beaded up but 3 shops haven't been able to get the other two to bead up....not even the truck Beaurepaires joint in Fysh.
    Sidewalls are too stiff and it's too cold to soften them up......anyone know a shop that do this regularly and may have more of a clue?
    I'll bring them out to WP anyways and might be abl;e to get them fitted there?
    Are you stretching them onto a wider rim or something, or the same rims they were on before? (assuming you are using a set of the same spec as prevoius)
    Stick them in a commercial oven Or get JoJo to fit them, dorifto style, with aerosol.
    other than that, I have no serious suggestions
  8. #53
    Sep 2008
    Put mega psi in them then go for a drive on them. Handbrakies will help. I havent done this myself and wouldnt recommend it, but know people that use it as a technique to fit avon formula ford slicks.
  9. #54
    They won't bead so can't get any psi in them.
    Same rims, same size tyres but latest gen. Stiffer than previous and ave never had them fitted this time of year.
    Well it sure as hell ain't gonna be any warmer in Gloomy Goulburn this Sunday
    Best of luck with it, hopefully the pro's at the track can get them to bead with their experience, one of the motorsport tyres trucks should be there surely......
  11. #56
    Hopefully there's a truck there otherwise I'll give the top gear nth pole gas fill a try
    Or maybe not. I've noticed this only seems to be done with steel wheels?
    Nov 2011
    How did you guys and girls go at the super Sprint yesterday?
    JoJo did you end up going drifting?
  13. #58
    I had a cracker day. I won my class, Type 4 D, which basically consisted of stripped out race cars and dudes in fancy driving suits....happy with that Even better, i was fastest outright Well, except for a Radical, but hardly something that should be pitted against a tintop?
    The only downside was a few niggly issues that stopped me getting as much time on the full slicks as i would have liked to get back in the groove. Hopefully i can have them sorted by tomoz as i'm back at WP again.
    Nov 2011
    What times where you getting Justen.
  15. #60
    No PB unfortunately, but i was down in the 1:07's the 1st session out on the slicks. There's an easy 1:06 in it with the current wheel alignment (not that i know what that is as it hasn't had one since being bolted to back together).
    I need my tyre temp gauge to work to get an idea how i am place for neg camber. The front left ball joint is shagged and there a 1mm or so of play there which means toe in/out is all over the place. I'm not hurting the tyres so it must be close, just need to home in on the sweet spot for these slicks as there's lots of time to be found when you do.
  1. SDMA Hillclimb 29th April 2012
    By JoJo in forum ACT Events
    Last Post: 04-05-2012, 04:59 PM
  2. SDMA Hillclimb 1st May 11
    By Tyrie in forum ACT Events
    Last Post: 04-05-2011, 07:52 AM
  3. SDMA HILL CLIMB Canberra Sunday 27th
    By airocobra in forum ACT Events
    Last Post: 06-07-2010, 07:50 AM
  4. SDMA HillClimb, 13th April + 27th April
    Last Post: 14-04-2008, 05:19 PM
  5. SDMA Hillclimb - this Sun 25/11/07
    Last Post: 27-11-2007, 01:17 PM
