MX73 xmember and 2JZ, its your only sensible option
Hrmm yes, im thinking about converting my SX70 (read: 1S-U power X71 Cresta)
It is rear wheel drive auto.
Now, the 1S-U is a 1.9L 4 CYL Carbi motor:
1S-U
Year:86
Bore: 80.5 mm
Stroke: 89.9 mm
Compres:9:1
Capacity:1832 cc
Power:95 hp@5200 rpm
Torque:152Nm@3400 rpm
Now, This poor 1S-U has had a blown waterpump and BHG which i have repaired.
The engine is like the Soarer having the 1G , its not right,
The car weighs around 1.5 tonne, and it has a 21 year old engine that makes 95hp.
Conversion needed ?
i think so !
now because the Cresta is a SX71 being X71 means that its an SX7 cross member which means the S range of engines *should* fit right ?!
So thinking again this is my daily *cheap* i need something S ?
What are my options ?
Could i simply install an S engine , or buy an MX73 crossmember and put a 5M or 7M in ?
Only problem i see with installing something like a 3S or 5S is that the East West engine will have to be changed to North South then "hopefully" bolt up to my A304 auto box.
Opinions People! !
<3
hello
Would a twin turbo 1UZ fit in there?
Would be way cooler than a soarer. And as such, you could sell the soarer to fund it!
ever considered the amout of work AND money in a TT 1UZ setup?
hello
No.
But this is the internet.
Beams plz (10 char)
MX83 crossmember, JZX81 mounts, 2jzge
Just put another S motor in their coff..Cheap and simple..
Keep it pimp..and slow!
Z20- SOLD
why not just buy another old toyota??? but if you insist, 3sge beams!!!!
yup
tooodles
gerald
ta22 Green with cream vinyl roof, 2t/3t hybrid with a few go fast bits on + 5 speed.
for simplicity,
MX73 xmember, engine, gbox and fuel tank
$500 conversion
hello
Heeeeyy...watch where u say such filthOriginally Posted by coFF33
Z20- SOLD
another vote for beams 3S here
blacktop of course
1990 JZA70 R - BLMQZ
m a n u a l
Dark green mica
14.118 @ 101.01 mph (Perth Motorplex, 24/05/06)
252.1 HP (Hyperdrive, 11/11/06) / 264.2 HP (XSpeed, 24/02/07)
2jzge gets my vote!
Hamgatan says:
i pwn my momma
1GGZE
cheap and easy to install but still good enough for a squirt or two
Destroyer of 'Drop Forged' spanners
1UZ + autobox
win
or failing that, a 5ME + W58 out of an MA61
Project Soarer II - Sold
Evo 5 - The silver fruitbox
