Results 1 to 15 of 27
Thread: Electric power steering
    Sep 2012
    Arizona
    Default Electric power steering
    At request I post my how to electric power steering conversion. This was done on my 1992 corolla all-trac wagon. Why some ask? Well the car recieved a engine upgrade. 4agze from a 89 aw11 mr2 and flogging a sc14. Anyone fimilar with this engine know the supercharger sits where the powersteering pump was. While my past 91 corolla with a "z" engine i just drove it pump removed. I found after picking up the wagon that i would liked having power steering. So began one of the stupid little projects we get are selves into.
    I originally post this modification/upgrade in my build over at the alltracwagon.net forum. 4agze build - All-Trac Wagon Network
    This is the EPS (electric power steering). First off there are two types of EPS i have encounter over the years. First is the style that use a electric hydraulic pump. These i have seen on sw20 2nd gen mr2 and mini coopers.
    This is a pump from a sw20.
    This the ecu for the sw20. I should note i have this setup for sale if any one in the U.S. what it.
    The second type is full ellectric. Where the electric motor is attached to either the steering column or steering rack. While there are many different versions of these. I will only cover the 2004 and new toyota prius and 2006 toyota yaris. I will note that this conversion can be done completely using parts from a 2006 toyota yaris. The most important part is the EPS ecu needs to come from a yaris that does NOT have abs. The one quirk is that the ecu looks for both the rpm signal and wheel speed signal from the can network. The eps ecu will not provide assit tell it see the either one of these signal. I did look into reproducing the can signal but it would not be cost effective. This is where the NON ABS ecu provides a work around. The non abs ecu does not get its wheel speed signal from the can network. It get the signal from the instrument cluster in a standard 5v pulse. The only quirk with this is tell it see a pulse the ecu does not provide assit. Once it has see the speed signal it will continue to provide assit tell the ignition is cycled off. I did look it to building a small pulse generator and circuit has a work around but after driving the car with out the work around i found that it did not bother me enough to build the circuit. I find that when backing out of a parking stall the assit will start just after i need to start turning the wheel.
    bottom is my stock steering column from a 1992 ae95 corolla alltrac wagon. The column is a tilt column.
    The top is the EPS column from a 2004 toyota prius.
    I started by disassembling my stock column.
    sorry my pic are not exact detail on tear down. But if you are attempt this conversion i would hope you would have the skills to figure out how the column comes apart.
    The 2004 prius column has two parts, the top tube is slide over the tube that is attched to the motor housing. The outter tube is crimped to keep it from sliding apart. I cut the crimped part with a die grinder and then was able to slide it off. The above pic is the column still together and i should note the upper tube has the factory mounting brackets attached to it.
    this pic is laying everthing out to work out how eveything will go together. The left part is the stock tilt mechanism, note the shaft sticking out. The next part is the main stock housing with the stock mounting brackets and ignition cylinder/switch. Then the prius part the first tube houses the torque sensor.(please take care to not damage this sensor.) the torque sensor is what to ecu uses to determine direction and amount of assit required. there is also a bearing in the housing. Next is the motor and gear housing. You will note this has a long shaft sticking out, this shaft hold the teeth that torque sensor looks for. On the other side is the output that will go the steering rack. The last part and not shown in the pic was the upper shaft from the prius, this shaft splines with the shaft coming out of the motor assembly. This shaft was measure ti figure out the length need, then the shaft coming off the original title mechanism. I had to finish removing the shaft from the mechanism. Once removed and measured out i cut the two shaft and wielded them together.
    from the joint to the left is where the steering wheel mount. To the right of the joint first you will notice a collar with a notch. This notch is for the steering wheel lock when the key is out.
    Necked is the housing which also was measued out cut and wielded together. But before it was wield i had to remove the torque sensor.
    first i had to desoilder the circuit board. This is the four larger holes at the top of the circuit board above my finger.
    Check out my ae95 4agze sc14 build. http://www.alltracwagon.net/forum/m-1347147405/ or check out the ride info at http://www.toymods.org.au/forums/for...agze-sc14.html
    Sep 2012
    Arizona
    Default Re: Electric power steering
    then carefully pulling the white cylinder plastic piece out. You can also see the bearing. This was left and seems to have servide the heat of wielding.
    the housing all wielded up on the right side. I had to remove the lower mounting bracket and wield it back on with the EPS housing. Once wield i reinstalled the torque sensor and soilder the circuit board. Then install the upper shaft in the tilt mechanism and remounted the mechanism to the main housing.
    All finished and ready to install in the car. I should note that make sure you test fit and measure to make sure the motor will not hit anything once installed.
    And here it is in the car.
    Now that the easy part is done on to the hard part wiring. I should note that when you order your ecu make sure to get the wiring harness pig tails and connectors. With out them you may have a fun time locating the connectors (i have already tried order in the connector from toyota and while i had the part number toyota could not order them in) or end up soildering the wires striaght to the ecu.
    First you will need to locate a location to mount the ecu, which will need to be close to be able to plug the harness from the column. I mount mine to the dash main brace to the right of the steering column. Sorry i did not take a pic of it mounted. Next will be building a high amp circuit. For this i used car audio amplifier power wire of 8awg, and a 50 amp fuse. The ecu has four connectors, one for the main power which is 2pins, a second for the motor also a 2pin connector. Then the torque sensor connector and last the main connector. The connectors for both the torque sensor and motor should just need to be plugged in. The high power two pin and main 12 pin connectors will need to be wired up. The high power will be the ground and 50 amp fused wire. Note the ecu has its own high amp relay so the 50 amp wire does not need to be switched. On the main 12pin connector will use only 4 pins, they will be pins 2, 5, 6 and 11. Pin 6 is the switched 12v power with 10amp fuse, this needs to be switch from the ignition switch. Pin 5 is the speed sensor signal wire. This need to be tapped to a 5v pulse generated signal. My ae92 corolla all-trac has a speed sensor built into the instrument cluster. I should note my car produces a 12v pulse but the eps ecu has fuctioned find despite the higher voltages. If your car does not produce a speed signal then a google search for a speed sensor adapter for aftermarket cruise control should work. The last 2 pins may or may not need to be used. If you bought both your ecu and column from the same vehicle then the torque sensor should still be calibrated and it should be plug and play, also some mix matching of columns and ecu may still function with out a problem. If not or if down the road there is a problem and the torque sensor need recalibrating, then these two pin will be need along with a dlc 3 connector. Pin 2 is the "SIL" this is the serial communication wire to go between the scan tool and the ecu. Pin 11 is the "TS" and this is the ecu diag pin. When this pin see ground then the ecu will communicate with the scan tool. The dlc3 connector is only needed if you need to connect a scan tool.
    No replies?? What?
    Very well done working this out!
    Ill look at doing this in the future to my GT4 (Celica Alltrac for you ).
    It does make me wonder if the Yaris assist motor will be strong enough to handle the rather heavy steering on the GT4 though.
    Most people seem to use the column out of the Barina/Corsa
    Sep 2012
    Arizona
    No replies?? What?
    During my research i did come accrossed several people with stock corolla with eps that said they could under the right conditions get the system to hot, causing it to go into limp mode. Which is assist reduce to i bieleve 30% tell the ecu/motor cool back down. But from what i have found after i got mine up and running is a company in europe that makes little controlers that wire into the ecu so you can manually adjusted the amount of assist. (Welcome to the Rallywiz online store. - www.rallywiz.com - (Powered by CubeCart)) this way you can turn the assist down if you are racing. Has for my car i do not race it, i just want a little more power and i had the 4agze engine sitting around.
    Jun 2008
    Great little write up!
    I am looking at performing this modification for my electric Sera project.
    Can I ask what the part number for you ECU was?
    I am looking at a buying a 2002-05 unit with ECU part number 89650-0D040.
    Cross reference on toyodiy.com dose not mention anything about ABS or not.
    Out of interest I have had a play with an 2008 model yaris unit.
    It draws around 5-7Amps while turning the wheel stationary on the concrete driveway, peaks at 30A when pulled hard lock.
    -A
    Sep 2012
    Arizona
    The ecu I used is "89650-52140" it from a toyota yaris 2006 with out abs. I should note that this is usdm spec. The key during my research into this conversion is. First the ecu has to match the eps type. The first gen prius used the assist built into the steering rack. This type of ecu will not work the colmun style eps. The second is the ecu needs to have an analog speed sensor input. And not get its speed signal from the can network. The best would be to find an ecu colmun combo where the ecu powers up over a rpm signal.
    My setup does not work when you start the car. But once it sees a speend signal then it powers on and works great tell i turn the car off. I have looked into build a small pulse generator device, That would come on when i first start the car to trick the ecu into powering up. But the more i have driven the car most times i bearly notice.
    Feel free to ask any more questions. Also sorry if my explaination is confusing. I am writing this on my iphone on my lunch break. Also if you post wiring diagrams from the eps system you are looking at getting. I maybe able to determine if it will work.
    Jun 2008
    Great,
    Thanks for the info.
    I have found a bunch of units in the UK for sale quite cheep.
    Its just difficult to tell if they came out of ABS or NON ABS cars.
    If I cross reference your part number on toyodiy.com it comes up with:
    89650 Computer Assy, Power Steering
    89650-52420 ABS-WITH(Without Brake Assist)'.
    89650-52140 <notext>
    Somewhat cryptic!
    the Ausie & UK part numbers do not show anything about ABS at all :/
    Time to go visit a few local wreckers me thinks!
    -A
    Sep 2012
    Arizona
    Look forward to seeing your results!
    Nov 2011
    I have wired up some Suzuki ignus electric power steering motors and also some bmw mini electric power steering motors
    They are pretty easy to fit
    Jun 2008
    Got mine working on the weekend
    This was with an ABS module too. pn: 89650-0D100
    More info on my SERA EV build thread.
    -A
    Sep 2012
    Arizona
    Congrats!! Glade to see some one else take on this upgrade and get it working!
    wa
    Just chiming in here.
    I have the 07 Yaris EPS working on my KP61 and it doesn't require any inputs, I've had it working with and without any external inputs. Sometimes you do have to rock the wheel before it will wake up though. Maybe one time out of 20. I assumed this was because of the lack of initial pulse form the speedo (I have a reluctor for speed back to ecu on mine like the ae86) but after disconnecting it out of curiosity it appears to be doing nothing different.
    I actually jumped on here to lure VA61DETT into the thread but he is already here
    My Corolla ! - 4AGTE
    KP61 - 4AGE
    Sep 2012
    Arizona
    With the non abs ecu and the speed sesnor connected, watching the data list on a toyota scan tool i can see the system reduce assist has the speed increase. I do notice the speed is of by about 8 or 9 miles so the system reach the speed of lest assist earlier then if in a yaris. My only problems has been that it will not power up tell it see about two pulse from the speed sensor.
    Which most of the time happens fast enough to not notice. But ever once in a while it does take long enough that it would be nice to have it just power up. My two ideas are, first to build a small pulse device that would create several pulse on start thus causing the sytem to power up. The second is to use and arduino can board, connected to a functioning yaris and record the can signal during start up the just replay the recording to the eps ecu can lines. This one might be a little more tricky. But from my reacher and undrrstanding of the toyota can system the eps ecu is just looking for the rpm signal from the engine ecm over the can network. Any ones thought on this would greatly help both me and anyone playing with this setup.
    After looking into EPS systems for a while, im going to use a unit from a RAV4 (2007 ACA33R to be precise).
    I didnt like the look of the Yaris unit. Its too small (im worried about it overheating in motorsport use), and isnt as advanced as the later Toyota EPS's.
    I picked the RAV4 EPS as it has a thicker torque rod (should give better steering feel), and has a large motor which wont overheat easily.
    RAV4 EPS next to the GT4 column:
    The RAV4 EPS is purely canbus, so after many (20-30) hours of sleuthing ive worked out which canbus signals/packets it requires to work properly.
    Im going to program & install one of these displays in the dashboard:
    The display will take a normal gearbox speed signal input (and maybe others), and using a programmable 2D map & other settings, send the appropriate steering assistance info to the EPS.
    Im now in the process of installing the EPS column into the GT4.
    Im going to use the full RAV4 column, stalks/switches. It actually fits easier than i thought it would
    It'll be sometime (month or so) before the car is back on the road... so it'll be a while yet before i can properly test how well this EPS works in the car.
  1. power steering --> huh?!
    By Bahnugget in forum Tech and Conversions
    Last Post: 17-12-2006, 03:30 PM
  2. Which power steering box is going to fit a 22.
    By "Z" UTE in forum Tech and Conversions
    Last Post: 19-06-2006, 08:16 PM
