Results 1 to 8 of 8
Thread: help with factory alarm (95 camry)
    hangin loose full o juice 1st year Apprentice
    Default help with factory alarm (95 camry)
    hi all
    ive got a 95 camry daily driver and i have a problem
    i broke the remote for the factory alarm and now i cant start it..
    is there away to disable the factory anti theft ??
    i broke the remote ages ago and have been able to drive it fine because i never turned it on
    however this morning i took the battery out of the car and when i put the new one in the anti theft system
    armed itself.....
    Default Re: help with factory alarm (95 camry)
    If the factory remote battery goes flat or the signal is blocked by something (areas of high RF interference like broadcast towers or high-voltage powerlines can do it) then you can still unlock the car with the keys but the immobiliser will still be active, which is what is stopping you from starting the car. You can get around this by either waiting half an hour after unlocking with the keys before attempting to start, or check the glovebox for a little socket which you can push the remote into to disable the immobiliser. Note that I think this only works on the lower-spec models (it does on my parent's '96 CSi) that don't have a full security alarm system, just the basic remote central locking/immobiliser/horn alarm instead of an aftermarket-style chirp w/ glass breakage sensors etc.
    Quote Originally Posted by sleepermx83 View Post
    nailed it.
    Never late in an x8
    It also helps to read the comprehensive instructions in the owners book.
    Jealousy is a curse
    Quote Originally Posted by madmont View Post
    Not everyone still has the original manual, especially if they're not the original owner...
    i have the owners manual and have read it and it says i need to stick the remote into the slot in the glove box to disarm it...my remote is screwed
    So you've tried putting the remote in the slot? You don't have to physically press the button or anything, there are two contacts on the nose of the remote which touch contacts in the slot - this will disable the immobiliser and also allow you to change settings like remote unlocking procedure, horn chirp etc by using the central locking switch and the security light.
    yeah tryed all that but it didnt work...i ended up ringing brian hilton toyota and they were very helpfull
    told me to turn the ignition on and leave it for an hour and it will disarm the anti theft for good...
    and it worked lol
  1. What should I look for in an alarm?
    By XR Pilot in forum Tech and Conversions
    Last Post: 06-12-2007, 09:08 PM
  2. Celica factory alarm / central locking
    By Shane205 in forum Tech and Conversions
    Last Post: 02-09-2007, 08:07 AM
