Results 1 to 15 of 15
Thread: 2zj-ge Ecu pinouts and wiring diagram
    Jun 2006
    Tasmania
    Default 2zj-ge Ecu pinouts and wiring diagram
    Hey guys, i know there is a thread dedicated to wiring diagrams but no help as yet and this is very urgent.
    Engine is in a st141 corona and is near ready to hit the key bar a few wires that need connecting at the ecu like the batt feed, IGN feed and earths.
    Ive found 2jz-ge ones but not for the soarer, this is a 4 plug ecu and i cant find anything anywhere on any forum.
    Someone please help me, track day in 5 days
    Default Re: 2zj-ge Ecu pinouts and wiring diagram
    1JZ and 2JZ in the soarer run the same plugs into the ecus so possibly the same pinouts on the body plug
    http://soarercentral.com/sc-forum/me...nouts-2211.pdf
    Jealousy is a curse
    Jun 2006
    Tasmania
    Hmm thanks for that, i will have to try it worst come to worst
    Would love to be sure though
    Thanks a lot man
    Jun 2006
    Tasmania
    ok from what i a see the ecu doesn't need start signal to run?
    Maybe it just relys on the AT neutral switch?
    Jun 2006
    Tasmania
    Using those ecu pinouts above i've wired the ecu in, only things i powered up was the +b, IGSW and batt terminal
    Anything else that needs it?
    The coil has no ingition and its not firing or anything obviously, im starting to think the ECU pinouts for the1jz are different
    Need help bad thanks
    You should have m-rel going to the relay to supply power to the ecu which comes back through b and b1
    have you supplied 12v to the injectors?
    here is a wiring diagram
    http://www.1jzsoarer.net.nz/files/Soarer3.pdf
    Jealousy is a curse
    Jun 2006
    Tasmania
    Well ive wired 12v to those terminals (provided that those pin outs posted at the top were right) just didnt use th m-rel pin to trigger it, dont think that will matter.
    I thought the ecu would supply the injectors?
    Do you have pin outs to go with those wirin diagrams so i can work these injectors out?
    Or seeing as the huge rush im in maybe you could be nice enough to tell me lol
    You should have a wire running from the ignition to the injectors and igniter through one of the body plugs on the engine loom possibly a black/orange wire
    Jealousy is a curse
    Jun 2006
    Tasmania
    Hey man i found a plug with thick blackorange wire, powred it up and now have spark. As far as i can work out injectors aren't clicking
    Any info on where to head from here?
    Make sure you have 12v at the injectors take off a plug and measure the volts. If you have 12 v take plugs off injectors and make sure they click when you put 12v across them. They may be stuck shut from sitting for some time
    Jealousy is a curse
    Jun 2006
    Tasmania
    No voltage at the injectors when the ignition is on but they click when i power them up
    Wonder if i missed anything at the ecu... or if i even used the right ecu pin outs lol.
    you'd think if they were wrong i wouldn't have spark though.
    Hmm any ideas guys, help is much appreciated car is ready for track this weekend apart from this littl hickup lol
    Quote Originally Posted by skin View Post
    Maybe you haven't applied power to the injectors ?
    One pin will have 12V (measure from battery -VE to injector pin), the other pin will go back to the ECU (The ECU earths this pin to turn the injector ON).
    On the same plug that you connected Black-Orange wire to get spark I suspect there will be another wire that goes to the injectors to power them
    Hint: You can use a multimeter in Ohms / Resistance mode to trace back the wire from the injector to the plug it goes to
    Wilbo's JZA80
    Wilbo's JZZ12
    Jun 2006
    Tasmania
    Runs like a champ, thanks fella's
    skin, what was the problem, which wires were wrong.
    cheers Chuck
    MS51Crown Coupe,
    Jun 2006
    Tasmania
    nothing was wrong just missing couple of things,
    Its not actually runnig real good lol misses bad under load and doesn't even rev properly
  1. JZS155 Crown 2JZGE VVTi Wiring Diagram needed - HELP
    Last Post: 30-04-2013, 06:28 AM
  2. Mx 83 wiring diagram and ECU pinouts.
    By crowncustom in forum Tech and Conversions
    Last Post: 11-07-2009, 07:38 PM
  3. 2JZGTE VVTi wiring diagrams and ECU pinouts
    By 98SZR in forum Tech and Conversions
    Last Post: 02-07-2009, 11:55 AM
  4. 5VZ-FE Auto Pinouts & wiring Diagram wanted
    By TheToyman75 in forum Tech and Conversions
    Last Post: 27-02-2007, 04:04 PM
