Chromed aluminium???
Polished perhaps?
Hi Guys, i've got some more products i think you will like.
Offical Release
New to Otomoto Pty Ltd are these chromed aluminium mandrel bends. Ideal for use in intercooler kits and mounting pod air filters, they are available in both 2.5in (63mm) and 3in (76mm) diameters and are constructed from mandrel bends, all featuring ribbed ends.
They are also thick enough to be easily cut and welded as needed.
There are four types of aluminium pipe available with the straight sections retailing for $20.00, 45 and 90-degree bends retailing for $25.00 and the 180-degree bend retails for $30.00. Both diameters are the same price.
Polished perhaps?
No, chromed. I'm told the process is much like anodising.
Then welding them would probably be a really nasty proposition..
TIGs don't like coated materiel in my experience.
True, but it can be done and rechromed.
Available soon (mid February) will be raw aluminium finish so the bends can be cut and welded then polished.
Whats the overall width of the 180deg bend?
I've yet to measure the one on my car, but its not tight enough and fouls.
2" and 2.75" also? come on then my life would be easy.Originally Posted by dori dori
you can take the coating off with a linisher and weld it as i have done it many times b4 but it does take some getting use to as the impurities come through whilst welding.
let me know when the raw stuff comes in and ill be there in a flash.
linden
Originally Posted by WHITCHY
The overall width of the 63mm 180degree bend is 280mm.Originally Posted by CrUZida
The overall width of the 76mm 180degree bend is 310mm.
Hi Linden, i will see what i can do on the 2in but i'm not so sure on the 2.75in. not sure how much demand we will have for it.Originally Posted by The Real Roadrunner
i may also be interested in a couple 2inch 90degree chromed bends..but would want them within the month....
1977 RA23 Celica -> 1ggte conversion [SOLD]
MA70 Supra 1JZ 5speed [SOLD]
Current: IS200 1JZ VVTI 6 speed
2.75" is most toyota and nissan TB size, demand would be pretty high if you were to put kits together for you coolers to suit a variety of cars.Originally Posted by dori dori
2" is the majority of t25 size turbos so should be plenty of uses for them also![]()
see what you can do and let me know.
linden
Hi Linden, will do.
Damn, same as whats on the car.Originally Posted by dori dori
No drama.
Yer 70mm would be awesome!!
None of this polish stuff to be had.
R.I.P Peter Brock.
