hi all.
i weighed my 1j using my getto scale system. me and a friend both checked the system for accuracy (by standing very still while the other one added up the weights) and we also used a W55 to check the system and it works fine.
the 1jz has no oil in it, it has no power steer pump, no air con. the flywheel and clutch were counted as well as all the intercooler pipes etc.
the results,
1jz= 225kg
W55 with dellow bellhousing= 41kg.
if you would like to add to this thread with REAL engine weights (NOT bloke down the pub told me) that you did/saw with your own eyes then go right ahead.
the information about engine weights on the net is scetchy at best so keep it accurate.
maybe if this thread takes off we could change the name and sticky it? mods? what do you think.
latter,
sheepers.
69 MS51 crown coupe. http://www.toymods.org.au/forums/sho...980#post835980
RA23 celica with 1JZ-GTE. http://www.toymods.org.au/forums/sho...sheepers+jza23
76 RA28 celica 1UZ, http://www.toymods.org.au/forums/showthread.php?t=12299
Hmmm i wonder how this would compare to a 18RG with the W50 gearbox interesting to know.
Cheers Pete
1977 RA23 LT CELICA
Here it is right here http://www.toymods.net/forums/showthread.php?t=23121
