Results 1 to 15 of 26
Thread: xT Series Engine Variants
    Default xT Series Engine Variants
    Engine model and generation: 3/2TG Hybrid
    Top End Modifications: Cams are 284 duration .433" lift in a 88262 non hemi head
    Bottom end modifications: 13T bottom end with flycut and reduced dome pistons to suit head
    Forced induction: N/A
    Management: Weber DCOE40 With 36mm chokes
    Fuel used: Shell optimax (unpopular i know but i've never had a problem)
    Intake: Weber DCOE40 on an early 2TG manifold
    Exhaust: Pacemaker 4-2-1 extractors with 2-1/4 exhaust, hotdog resonator and straight through rear muffler
    Driveline: Unknown clutch, T50 and welded T series diff
    Default Re: xT Series Engine Variants
    2TG/3T Hybrid
    3TC bottom end used
    2TG 88261 head used
    Stock standard 88261 head and cams
    Head setup on engine to run approx. 10.2:1 compression ratio
    Stock standard internals
    Flycut pistons
    Forced induction:
    NA engine
    Management:
    N/A
    Fuel used
    98 octane only
    Intake:
    40PHH Solex Carbs (Twin side draught)
    Exhaust:
    Genie Extractors, 2-1/4" exhaust
    Driveline:
    3T flywheel (approx weight 12kgs - to be confirmed)
    Standard TA22 diff
    T50 gearbox
    Comments:
    Dyno graph produced when engine was poorly tuned, with stretched timing chains, worn timing guides and a leaking upper timing chain tensioner.
    Mods since this graph:
    3.9 T series diff centre
    Upcoming mods over the next few months include:
    TODA racing flywheel at approx 3.5kg with Xtreme Heavy Duty Clutch
    Ported 88220 head with cams of unknown specs
    Ram tubes and socks
    Will post new dyno graph for comparision after these mods
    Toyota Car Club (Qld)
    2TG.
    Stock.
    Stock. Block had 40thou overbore when I rebuilt it.
    Induction:
    Twin 40mm Dellorto Carburettors.
    Management:
    N/A
    Fuel used:
    Regular pump fuel 95 octane
    Exhaust:
    Extractors, 2 inch press bent system.
    Driveline:
    T50 gearbox, stock KE38 corolla diff.
    Comments:
    This engine was rebuilt with all new bearings, pistons, rings, gaskets, valve stem seals etc etc. The head was reconditioned at the time also in 1998.
    The dyno run was carried out about 800km after the rebuild.
    My KE25 thread
    Junior Member Grease Monkey Hulk's Avatar
    From previous owner - Cheers Jake!
    3TGTEU Gen2 (watercooled turbo) from TA63 Carina
    Stock top end
    Stock bottom end
    Forced induction:
    Factory CT20 Turbo
    Management:
    Factory ECU + Knock Sensor
    Fuel used
    Intake:
    1GGTEU Front Mounted Intercooler
    Exhaust:
    2.5" Mandrel Bent Exhaust From Turbo Back
    Driveline:
    W55 + Stock TA22 Diff
    2T
    Std sized valves
    Mild porting
    Shaved to give 10.5:1 compression ratio.
    Double valve springs (unknown inners, OEM outers)
    1mm O/S Toyota 9.8 pistons
    Stock rods
    Stock crank
    Ligtened OEM flywheel 6.6Kg
    Stock clutch
    All balanced
    Mild cam, used to be called a 3/4 race cam back in the eighties (30/70 but cannot recall exact)
    Standard points but recuved distributor with vacuum advance removed.
    Induction:
    Mikuni/TRD sidedraught manifold
    Dual PHH44 Mikuni
    Main Air jet #160
    Main jet #145
    Pilot jet #60
    Outer Venturi #34
    Fuel used:
    Std ULP
    Exhaust:
    4 into 1 extractors 2.25 inch exhaust
    Driveline:
    stock T50 and T rear end
    Regards
    Rodger
    2T
    TRD O/S valves, seats and spring retainers
    Good porting
    Shaved 1mm, with pistons gives 11:1
    Double valve springs (TRD inners, OEM outers)
    4mm O/S TRD/Weisco (1740cc)
    Stock rods
    Stock crank
    H/D Exedy
    All balanced
    Mild cam, used to be called a 3/4 race cam back in the eighties, 9.5mm lift (30/70 but cannot recall exact, out of the engine above)
    Induction:
    Dual PHH44 Mikuni
    Main Air jet #200
    Main jet #140
    Pilot jet #60
    Outer Venturi #34
    Fuel used:
    Std ULP
    Exhaust:
    Driveline:
    Comments:
    Not ideally set up yet. I need to refine tuning but this combination is still extreamly drivable. This is the first time this motor has been on a dyno in its life.
    This was my competition engine originally built in the Mid/late eighties with little freshening up to now be in my Green TA-22, replacing the 74.5rwkW engine above.
    Regards
    Rodger
    This run was done first on the CCG Dyno Day 6 and is being used by me to test a jetting set up with S5 Solexes. A pig to drive.
    [IMG][/IMG]
    Comments:
    Shows a huge hole in the performance. This is due to a way lean mixture and is caused by a huge lack of air speed. Not being fast enough through the outer venturis (chokes) to draw enough fuel from the main system.
    Shows it being compensated for by the Pilot system and starts to pick up again at the top end where air speed comes up. The Main could go to #150 and Air to #180 and would help compensate. #32 Venturies would be better. Looks like it has good potential for low down torque, with a lazy 79rwkW at 130kmph in 4th gear.
    As for previous post of mine
    Induction:
    This time around:
    Dual S5 Solex
    A typical 2T-G jetting of:
    Main Air jet #150
    Main jet #140
    Pilot jet #65 with drilled to #100 Pilot air. Except these to make it just driveable.
    Outer Venturi #34 (normally #30 or #32)
    Fuel used:
    Std ULP
    Regards
    Rodger
    Junior Member 1st year Apprentice quikestsilva's Avatar
    Apr 2007
    tassie
    Car - 1981 T18
    Engine - 2TG, head overhual, shaved head, new rings, bearings, timing chains, extractors, hot cams (unsure of the specs), abit bigger then standard jets (unsure of the specs either)
    Link below for pic of dyno reading
    Less cheese than a Grease Monkey andurils_sheath's Avatar
    2T-GEU 262 Head
    Race Port and manifold match ported and head freshen up
    None
    Induction:
    Dual PHH40 Mikuni
    Main Air Jet #240
    Main Jet $150
    Pilot jet #55
    Outer Venturi #34
    Fuel used:
    BP Ultimate 98RON
    Exhaust:
    4 into 1 extractors 2 inch exhaust
    Driveline:
    stock T50 and locked T rear end
    Comments:
    This is far from its potential but a good starting point. The jets are way too large, I think around 200s would be better, the AFRs sometimes getting as rich as 10:1. The dyno doesnt show the low rpm section where the car has a huge flatspot. The afrs are up around 16 or higher. I think bigger pilots should solve this. Will get another dyno after the mods i have planned are completed as a comparison.
    EDIT: Changed to a 65 pilot that i had sitting around. Now its much nicer down low. No more flat spot. I still need to sort out the top end. With a smaller main air.
    Quote Originally Posted by Zapp Brannigan
    In the game of chess, you can never let your opponent see your pieces.
    Nov 2007
    2T
    Rebuilt and ported by Motor Improvements
    Polished rocker arms
    H beam connecting rods. Most likely Fraser Engineering rods from Adelaide.
    Heat treated and stress relieved crank shaft.
    Steel main caps
    Unknown pistons, probably Specialised Piston Services of Melbourne or perhaps flycut Wiseco.
    Cam is either Speco Thomas 2T865 (312 degrees duration) or 2T935 (336 degrees duration). Motor Improvements is a Speco Thomas company
    Compression around 13.5:1
    Motor Improvemnts dry sump.
    Induction:
    Twin 48 DCOE
    Mains 165
    Management:
    Points
    Modified full mechanical advanve, 33 degrees total timing
    Fuel used
    Avgas
    Intake:
    Motor Improvements independent runner
    Exhaust:
    Motor Improvements
    Driveline:
    Steel Flywheel
    Tilton Clutch
    Holinger 5 speed transaxle
    Comments:
    Dyno sheet for a previous motor in my car, when the car had a different owner. Car is an Australian Formula Two. Race weight is 510kg.
    nuts Grease Monkey
    auckland
    done in 4th gear. probably could be better if running leaner than 10:1 dip in power we think due to weak valve springs.
    Car: ke70 SR Coupe
    Engine model and generation: 3T-GTEU
    Top End Modifications: stock
    Bottom end modifications: stock
    Forced induction: ct20 with bleed hole + extra spring on wastegate 10.6psi. no intercooler
    Management: stock tt142 3tgte efi
    Fuel used: 95 or 98octane pump gas (cant remember)
    Intake: pod filter
    Exhaust: 1.3/4" te71 exhaust
    Driveline: w55, 3.9 ratio diff
    -Mark
    E2 + E7 fan
    Yeah that's right, i'm a Grease Monkey texasflysuperstar's Avatar
    Jan 2007
    Gold Coast
    double post
    TA 22 - Top Coupe and Best Bodywork
    1994 Fours and Rotary Nationals
    Built by Alex Sumner
    Jan 2007
    Gold Coast
    Engine model and generation: 2TG/13T Hybrid
    Top End Modifications: Major head work, Thomas Cams (spec's unknown)
    Bottom end modifications: Stock 13T with Hi Energy Sump
    Management: Ignition Developments Electronic Ignition
    Fuel used: 91 RON Unleaded (Caltex)
    Intake: 45 DCOE Weber x 2
    Exhaust: Genie 4 into 1 Extractors, 2 1/2 Inch S/S System with S/S Super Turbo Resonator and Muffler.
    Drive line: Standard 5 Speed with 4 Puck Brass Button Clutch and RA40 GT diff with 4.11:1 gears
    Canberra Celica Group 1st year Apprentice Akaoni (Casey)'s Avatar
    May 2007
    3TG Hybrid
    Top end modifications:
    2TG 222 head
    Big standard valves
    286 duration .414" lift cams
    Mild porting
    2TG 262 block
    2.0 litre stroke (78mm 3T crank) and bore (89mm)
    10.5:1 WISECO forged pistons
    Pistons and driveline balanced
    Forced induction:
    None
    Management:
    Electronic ignition
    Carbies baby!!!
    Fuel used:
    Caltex Votex 98
    Intake:
    Twin side-draft Webers DCOE40
    34mm chokes
    Electric fuel pump
    Exhaust:
    Extractors
    2-1/4 system
    Driveline:
    Standard clutch
    T50 gearbox
    Standard diff
    Comments:
    Big thanks to Jason Fulton, the Canberra Celica Group and Phillip Head Services.
    Pretty happy with it!!!
    Casey
    Akaoni - My Red TA22 - BEAMS Blacktop (On the Backburner)
    Slick - Wife's Blue RA28 - BEAMS Blacktop (In Progress)
    Betty - White Hilux Daily - Stock Awesomeness
    Dot - Black Kluger Kiddy Wagon - Stock and Soccer-Mum-tastic
    Canberra Celica Group - http://canberracelica.org/
    Stage 1
    Engine model
    2T-G
    88260 head
    Shaved head
    RR4 Double valve springs (Forum sponsor)
    235* at 0.050 inlet cam (0.013 valve lash)
    248* at 0.050 exhaust cam (0.013 valve lash)
    110* LSA
    match ported head in/ex
    ported Redline manifold
    Kameari adjustable cam sprockets in/ex
    Kameari idle sprocket.
    Kameari 0.8mm metal headgasket
    Decked Block 2T 8101751
    Taiyo 88.5mm 1750cc pistons with 28cc dome
    3T-GTE con rods
    BRD High volume oil pump
    Type of induction:
    Normally Aspirated
    Management:
    Weber DCOE45 (jetted for street) with aftermarket ram tubes
    32mm venturies
    50F9 Idle Jets
    180 Air correction
    F9 Emulsion Tubes
    135 Main Jets
    50 Pump Jets
    Fuel used:
    98ron BP
    Exhaust:
    4-1 headers (short) heat wrapped
    2.5 inch press bent with resonator
    straight through muffler
    Driveline:
    Agawa Engineering 4.2kg racing flywheel
    stock clutch
    stock T50 (thanks Eddi)
    stock T series diff
    Stage 2
    34mm chokes
    MSD 6AL-2 + Blaster SS coil (due to missfire at 6krpm+ with old igniter)
    4 puck clutch disc + custom pressure plate
    4-2-1 exhaust headers
    other set of cams.
    deepdishfactory
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
  3. xE- engine variants
    By c2888 in forum Dyno Results
    Last Post: 29-07-2007, 12:12 PM
