Results 1 to 12 of 12
Thread: reprogramming a delco ecu
    Junior Member Backyard Mechanic 1jzracing's Avatar
    Default reprogramming a delco ecu
    where can i find software and info for reading and reflashing a delco ecu
    still on the search for a cheap ecu to run ignition only and thought this might be worth investigation as an ecu can be bought for about $30
    i know the majority of them can be reprogrammed and the ones from VN or similar will be MAP sensor read
    a fool remains undescovered untill he speaks!
    Default Re: reprogramming a delco ecu
    from memory www.diy-efi.org, check under GMECM website.
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    hey i had quite a good look into doing this a while back, ill see if i can find all the links and info. as far as i remember you buy this programming board that programs the eeprom for delco and them download free software that allows you to retune the settings.
    some sort of multichip programming board with jumper settings for different chips and voltage requirements. have a look on ebay there was a really popular board setup from "dark" someone or the other.
    its not the best interface but useable, im sure there was a big forum on
    delco ecus and programmng them. 808 comes to mind like freight train,
    i think that was the particular ecu from camiras which is the one to use, so ill dig it up for you.
    there was one big advantage from delco, some sort of fuel feature that
    allowed economic running, supposedly gm spent millions refining it or something...
    i think for me it was a competition between using the delco or megasquirt setup - the megasquirt has a HUGE following and many helpful people on their forum, and then i discovered adapatronic which also has all sorts of features too and seemed a much easier, better route to go.
    all of this is off the top of my head and may not be entirely correct but its food for thought anyway
    Add Lightness! Grease Monkey spectral's Avatar
    Hi mate,
    A *stack* of good info here :
    http://forum.pulsar.org.au/showthread.php?t=26353
    the pre-$$$$ kalmaker worked well, but now it is all donglised etc..
    see if you can get your hands on the old software??
    You don't really need the Kalmaker stuff.
    Just grab an EPROM burner ($60 of ebay) and an eraser ($50 again) and tune with software such as : http://tunerpro.markmansur.com/ (some screenshots here : http://tunerpro.markmansur.com/screenshots.htm)
    You can even datalog using a ALDL cable : http://w1.601.telia.com/~u60113744/s...dl/winaldl.htm
    awsome stuff guys
    i will sift through it all and sus it out
    yea.... kalmaker lookes like the bigest ripoff now with so many aftermarket ecu's about
    because im only using ignition it "should" be farly easy once i can get in
    i only mentioned kalmaker cos when it first came out it was under $500, it worked, and there was no security shit on it.... but they cottoned onto people copying it etc pretty quick...
    looking promising, that pulsar forums thread is great ......all 19 pages!!!
    found free software that looks very good - tuner pro
    all i need is an eeprom burner ($40 ebay) and a replacement eeprom to use instead of the standard eprom, which is just a $10 ic chip from the likes of jaycar,
    problem is which compatable one to use...any ideas?
    then its a matter of dumping the data from the old infra-red eprom onto the software (or downloading a new one) making the relivent adjustments and reloading it onto the new electroic eeprom, which can then be reused over and over quickely and easily, for any subsequint changes and tuning
    PRESTO!! a fully programmable (and incredibly powerful) ecu for under $100
    theres a little more to it like fitting an ic plug etc. and theres no live tuning as i yet see, it will datalog once you get a bit more involved
    wheres the +rep love then mate
    Quote Originally Posted by spectral
    hehe .... fare call
    im a bit of slack arse with my rep, will endeavour to use it more so the big toyota love tree grows
    ........ then again now i will no doubt be inclined to waste untold hours [email protected]#$ing around with all this stuff .... and if i cant get it to work its all your fault!!
    rep sent
    Quote Originally Posted by 1jzracing
    hehe .... fare call
    rep sent
    I'm currently putting a Megasquirt into an old N13 Pulsar that I'm supercharging. I looked into modding the Delco ECU, or using a Jaycar DFA... but the Megasquirt came out on top when it comes to fun DIY factor and its a little easier to use than the Delco.
    The Delco can still do everything, but the interface with the 100s of tables gets a bit confusing and I don't have any of the EPROM burning/erasing/emulating stuff.
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 07:10 AM
  2. What ECU do you use?
    Last Post: 06-12-2007, 10:42 AM
  3. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:31 AM
  4. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 10:17 AM
