Page 2 of 8 FirstFirst 1234 ... LastLast
Results 16 to 30 of 117
Thread: How To ... Tacho Booster
    Default Re: How To ... Tacho Booster
    very nice and handy info to have hear, might try makin one.
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    Just an FYI for those who want to build themselves a tach booster and dont know where to get the parts.
    Visit your local Jaycar Electronics store and purchase the following:
    • ZT2115 - BC337 transistor - $0.42
    • ZR1007 - 1N4007 diodes, pack of 4 - $0.60
    • RR0582 - 2k7 resistors, pack 8, $0.46
    • SY4068 - SPST 4-pin relay, $7.95
    • PT4525 - red female spade crimp terminals, pk 8, $2.75
    • WH5532 - 3.0mm black heatshrink, $1.85
    • WH5533 - 5.0mm black heatshrink, $1.95
    • WH5554 - 6.0mm clear heatshrink, $2.25
    Now im too lazy to bother opening up a relay and doing some finicky soldering to the guts of it..... so i did an external version
    METHOD:
    1. Start by soldering the 2k7 resistor and 1N4007 diode together. Pay attention to the diode - the grey band should point towards the resistor
    2. Now solder the other end of the resistor to the base (B) leg of the BC337 transistor. Note the pinouts of the BC337 below
    3. Solder wires to the other two legs of the transistor. "E" of the transistor goes to earth, "C" of the transistor goes to the tacho output and also the relay coil.
    4. Attach spade terminals as follows, and connect to your relay.
    ...... butt scratcher?!
    Nice, i didnt think about doing an exterrnal version.
    Victoria, Mt Macedon
    Out of interest, does the relay click and carry on when running Witzl? Or are the pulses too short to actually move the contacts?
    Hen
    EDIT - Just realised that you could well have not connected it to a running car yet. In any case I'd be interested to hear once it's running.
    Hen - i've built one before and i dont remember it clicking at all.
    Will check again when i install this one.
    just remove the bit of the relay that clicks - just requires needle-nose pliers and a minor amount of unreasonable force.
    in reality i dont think the pulse would be anywhere near long enough to active the relay
    Junior Member Grease Monkey seamonsta's Avatar
    May 2007
    Hills Area Sydney
    You are a legend Mr Witzl, i have seen the diagrams on here before and never been able to actually work out how it should look. Maybe i am simple, (electronics wise) but that series of pictures on how to build one is the best i've seen, I think I will be able to do it now, thank you sir.
    Just a side note, regarding the question of the relay clicking..... It only clicks once or twice whilst the engine is cranking, but once the engine is running the pulses are too fast for the relay's mechanical parts to move enough to audibly click.
    Even if it did click and eventually die, it has no effect on the operation of the tacho booster whatsoever.
    Jan 2009
    Can any one make me one of these? I'd quite happily pay someone to do so as I simply don't have the skills.
    West Australia
    I just want to add to this thread for the next person that reads it.
    The wire your looking for running to the dash if you have an MA61/MZ11/MZ10 etc.
    Is located in the DRIVERS SIDE kick panel.
    Its a black wire with no dots/lines. Very skinny and plugged into the drivers kick panel fuse box next to a WHITE with BLACK STRIPE wire.
    IF you connect the "out -> to tacho" wire from your booster , to this black wire. your digital dash will work.
    May 2008
    Rep added to a bunch of you.
    I tried "Karl's version".
    The transistor is very fragile so I bundled the wires together to the relay packing. As I don't know a thing about electronics, will packing these componenets so close together affect anything?
    Oh I see how the clear heatshrink is holding the three wires from the transistor together. I'll have to amend that.
    '85 1JZ-GTE Celica Supra MA61
    '84 Celica Supra MA61 (Parting out!)
    being so close together wont affect the operation at all.
    What you have done, so long as it is wired correctly, will work perfectly. I probably wouldve used fully insulated terminals on the relay though, to avoid potentially shorting out the exposed terminals on the car chassis.
    Penrith BC
    im in the process of fucking around with my tacho..., grafting in some cheapo ebay tach mechanism that does 11k, and has a switchable 4/6/8cyl signal thingo on it
    now im running an autronic sm4, and ive never looked at what kind of output it has.
    i do know that the cheapo tach ive got wants a signal off the -ve from a coil, so im guessing thats the kind of signal this little circuit thing produces?
    so the thing is i guess, does the autronic sm4 tach output have the right kind of signal for an input to this circuit?
    ed
    edit - and before anyone whinges about the quality of my tach, yes its shit, but its just a guide i only really need the shiftlight
    ../delete/ban
    tech moderator
    Penrith BC
    uh, the other thing i was going to say, is there any merit to the idea of just hooking the autronic up to the tach, but chopping/jumping the first resistor on the tach circuit board (82k) on the tach signal input?
    im a COMPLETE schmultz with electronics. treat me like a child....
    ../delete/ban
    tech moderator
  1. Tacho tech
    Last Post: 04-08-2009, 04:10 PM
  2. Tacho Booster !
    By itchybum1 in forum Tech and Conversions
    Last Post: 28-03-2008, 09:36 PM
  3. 4 Cyl ---> 6 Cyl Tacho Swap.
    Last Post: 30-01-2007, 09:36 AM
