you havn't specified which turbo you are going to use. Depending on this will depend on how much boost you will need to make that power.
As an idea, GT35R with 0.83 requires 14psi of boost to make 300rwhp.
ECU is your choice.
Forged piston arn't required, stock bottom end is more then beefy enough to take 350rwhp. My current ute used to run 360rwhp all day every day. And all it is using is a decompression plate and a cleaned up head.
use stock MLS headgaskets. orining not required,
Need bigger injectors
Fuel pressure dependant on your fueling needs
external wastegate maybe depending on turbo used.....
Do a bit of research, all those questions you have asked are very generic in nature and not specific to the 3RZ.
