Gearbox and engine mounts will be no worries. Check the mounts and supports when you have the engines out. You can swap them from one block to the other, but given it's one fwd to another you shouldn't need to.
I would be surprised if the intake and exhaust aren't a match, don't know for sure. Also, hold on to the intake and any efi stuff you get so you can finish the job later. If you've got everything attached to the engine, just need the loom, ecu, and fuel pump, all of which should be pretty cheap.
Regards,
Chris
