Are you sure you mean 3/8 as other posts indicate you are after 3/4?
Hi all, i'm trying to track down a clutch master cylinder that has a 3/4" bore that will fit into the RA28.
I could get mine bored out potentially.. But checking if there is any off the shelf items that may fit. It can't be any longer than the RA28 item as it will interfere with the engine.
The Pajero NL clutch master is looking somewhat promising -
The only Toyota clutch master that has a 3/4" bore seems to be the MS65 but they are rare as hens teeth.
Joel
Oops yes I do mean 3/4"
I fitted a NL Pajero clutch master cylinder tonight.. Worked a treat! Shorter than factory RA28 item which is good for clearance with engine.. 3/4" and only minimal mods to fit.
The hole in the firewall had to be enlarged from 33mm to 35mm with a die grinder.
The 2x bolt holes for the Pajero MS had to be elongated 2mm each.
The Pajero uses a M12 thread where the RA28 had a M10.. So I am going to have to cut the flare off, fit new M12 bolt and re-flare.
