Results 16 to 18 of 18
Thread: MA45 - GA45 engine conversion
    TAS
    Default Re: MA45 - GA45 engine conversion
    With the MA45 having a steering box you might find that the twin turbos on both the 1G-GTE and the 1JZ-GTE make fitting either of them quite hard with a conversion to rack and pinion (prbly more work that you are after!).
    Why not 1GGZE instead then?
    jimmya Grease Monkey jimmy_a's Avatar
    Ahh - if you read my first post, that was my original plan. However, I've been busy - got myself a 5mge to put in cheap, until i can afford something else. A 1GGZE really does appeal...however the suggestion of a 2jzge appeals too - 7mge's...bah. I know they're good - but the headgasket problems...i guess a metal gasket fixes that.
    Anyway, for now, a 5mge will do. Any better engine upgrade will involve a lot more work - like dif, transmission, etc.
    Quote Originally Posted by blacktopspirit
    Gastro has hurt me for 4 days now! want to die! to scared to fart, to scared to eat, to scared to be more than 4 meters away from toilet!!!
    south australia
    i don't understand this comment.
    Aren't there a whole bunch of 1ggte powered ra40's floating around (brett celicacoupe springs to mind), they have steering boxes also.
    Or is the box completely different between ma45 and ra40 (ie due to ma45 having a powersteering setup) actually doesn't brett also have a powersteering box in his ra40 also (from an mx62)?
    obviously the crossmember is different and the nose length but i wouldn't have thought these would be showstoppers for a 1ggte.
    ps i know you are talking about 1ggze, but i just got confused why a 1ggte will struggle to fit.
  1. Idiots guide to a 1jz conversion into a MA70 bodied supra.
    By Xistant in forum Engine & Driveline Conversions
    Last Post: 12-07-2019, 05:11 PM
  2. MA70 --> JZA70 Conversion
  3. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
  4. Cooling Systems - Overheating Problems.
