Results 1 to 1 of 1
Thread: AE92 Corolla 4AGZE
    Default AE92 Corolla 4AGZE
    Hi, I'm selling my ae92 4AGZE, this is the same one that I made a listing for a few years ago, original thread is here:
    https://www.toymods.org.au/forums/th...-Corolla-4AGZE
    Long story short, I bought it in 2014, never really drove it, so tried to sell but somewhat unmotivated, so it sat in the garage for a few more years, now its time to go.
    I would encourage you to read the original thread as there is alot more detail on history of car. Specs is as follows:
    - 4AGZE Bigport head with a smallport (oil squirter) bottom end.
    - The engine was rebuilt about 40,000 kms ago by an ex Meridian Motorsport mechanic; head was recoed (valve stems, valve cut & face), new oil & water pumps, gates racing belt & tensioners, ARP head & rod bolt kits, race bearings, adjustable cam gears
    - Other engine mods done are; ABV mod, bigport cams, and I got the head reco company to tap a thread into side of head to plumb a brass elbow to allow oil drain into block (copy of the smallport head setup).
    - Running a 165mm crank oversize pulley and the later smallport SC12 with the smaller pulley.
    - 2" Exhaust and high flow cat.
    - Factory Front Strut Brace.
    - Koni Externally Adjustable all round (around 30k kms on them) Whiteline springs.
    - Whiteline Front swaybar (24mm adjustable) Whiteline Rear swaybay (22mm adjustable).
    - ALL suspension bushes replaced with Poly Bushes (around 40k kms on them).
    - Twin piston Superstrut callipers and modified DBA743 slotted discs. Custom SBS semi -race pads.
    - 15" ROH Alloy rims 195 50 15
    - Complete Corolla SX rear disk setup (SBS pads).
    - SX Instrument cluster including autometer boost gauge (installed in place of clock in sx cluster) and SC light.
    - AE111 Shifter (Shorter Throw).
    - Corolla SX wing
    - AE92 GT FX Front and Rear (matching) Velour Seats (From 3 door hatch, same as the ones from the levins).
    - Factory central locking.
    - Factory Power Windows transplanted from Series 2 Seca (everything). Series 2 door trims including power window controls on all 4 doors
    - Series 2 power Mirrors.
    - AE92 Bonnet scoop.
    - Dark Window Tint good condition.
    - Black carpet and dash plastics painted (properly).
    - MOMO Race Steering Wheel (looks new).
    - Mongoose MX750 Alarm w/ backup battery.
    - Fusion speakers and Clarion amp at back
    - Air conditioning
    - Registered in NSW, VIC, QLD, so is fully engineered and compliant in all 3 states. QLD owner spent ~$1,500 for full engineering and compliance.
    Car Condition:
    - Interior is in excellent condition, especially so for a car of this age. However very dusty
    - Exterior paint is in good condition. Some minor scratches and dings consistent with age. Also very dusty
    - Does not crank over as I suspect fuel filter is blocked after being not used for so long.
    - Selling unregistered.
    The car is currently in the location as per pics, however in a couple of weeks time it needs to relocated, and if im to put in the effort to get it towed, i would probably take it to the mechanics to get it going, then i would probably be asking for a higher price once it is cleaned up and running and not under time pressure.
    So please make an offer as is today, I just need it to go so an opportunity for someone to grab a bargain.
    Located in Brisbane
    Please call or text. text initially would be preferred mode of contact.
    https://www.dropbox.com/s/belonx20ne...914.JPG??raw=1
    https://www.dropbox.com/s/prx4wrn5ml...6916.JPG?raw=1
    https://www.dropbox.com/s/05rrgmhtsr...20AM.jpg?raw=1
    https://www.dropbox.com/s/v1qcz0w6h4...20AM.jpg?raw=1
    https://www.dropbox.com/s/c5ps2puggl...20AM.jpg?raw=1
    https://www.dropbox.com/s/s1o9cyurd9...20AM.jpg?raw=1
    https://www.dropbox.com/s/k6n8bix1ky...20AM.jpg?raw=1
    https://www.dropbox.com/s/diq2wf7020...20AM.jpg?raw=1
    https://www.dropbox.com/s/we6l7834v8...20AM.jpg?raw=1
  1. AE92 Corolla 4AGZE
    By oakmont in forum Toyotas for Sale
    Last Post: 08-03-2017, 11:16 AM
  2. Corolla AE92 Cruise [nsw]
    By nknoxy12 in forum Previous NSW Events
    Last Post: 14-02-2009, 12:43 AM
